[Geomoose-users] FYI: workaround found for feature reports not working
Jim Klassen klassen.js at gmail.com
Tue Sep 25 09:47:32 PDT 2012
This is a bit outside my area of expertise, but what does your data look like with regard to having the dashes?
I would expect that things should work as long as everything is using the name formatting for the PIN.
On Sep 25, 2012, at 11:32 AM, Mark Volz wrote:
> Hello,
> I reported that I was having trouble displaying the feature report for my parcels.  At first I thought there was a problem with the primary id [PIN] (I originally changed the name), or with the coordinate systems.  It turns out that the actual issue is that the feature report does not work when there are dashes in the pin number.  For example when the PIN is 01-234567-8, the feature report does not work.  If I remove the dashes so that the PIN is 012345678 then the feature report works.
> I thought this might be a bug so I filled a ticket.  In the meanwhile I will just strip off dashes from the PIN.
> Thank you
> Mark Volz
> GIS Specialist
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
