[Geomoose-users] mapfile troubles
Lee, Jon jlee at co.linn.or.us
Wed Sep 26 16:42:18 PDT 2012
I'm a complete newbie to Geomoose 2.6, and for the life of me, I cannot get the mapfile for a certain layer to produce an image. I keep getting a pink screen of death for that layer alone. I can direct the catalog to the proper coordinates, set up tools, but for some reason my mapfile is dead in the water. I'm enclosing it below.  If anyone would care to share some insight, I would be much obliged.
MAP
 NAME 'citylimits'
 SIZE 800 650
 STATUS ON
 EXTENT   7489144.302084 268236.183572 7904894.867319 465996.382924
 UNITS METERS
 INCLUDE "../../geomoose_globals.map"
 WEB
  METADATA
   'ows_title' 'Citylimits Maps'
   'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:3857'
   'ows_enable_request' '*'
   'ows_onlineresource' 'http://www.geomoose.org'
  END
 END
 PROJECTION
  'init=epsg:26915'
 END
 LEGEND
       STATUS ON
       LABEL
  TYPE TRUETYPE
  FONT vera_sans
  SIZE 8
  COLOR 0 0 0
       END
 END
   LAYER
  NAME citylimits
  DATA './citylimits.shp'
  STATUS ON
  TYPE POLYGON
  LABELITEM 'PIN'
  LABELCACHE ON
  LABELMAXSCALE 20000
  FILTER ([PARC_CODE] == 1)
  CLASS
   NAME 'citylimits'
   STYLE
    WIDTH 3
    COLOR -1 -1 -1
    OUTLINECOLOR 93 181 53
    MAXSCALEDENOM 15000
   END
   STYLE
    SIZE 1
    COLOR -1 -1 -1
    OUTLINECOLOR 33 106 43
   END
   LABEL
    TYPE TRUETYPE
    FONT vera_sans
    SIZE 8
    ANTIALIAS TRUE
    COLOR 0 0 0
    OUTLINECOLOR 254 254 200
    BUFFER 4
    MINFEATURESIZE auto
    PARTIALS FALSE
    POSITION cc
   END
  END
  METADATA
   # drill-down identify service record.
         'identify_record' 'templates/identify.html'
   # query.php / "Search Parcels" functionality.
   'itemquery' 'templates/search_result.html'
   'itemquery-filter' '/.*[qstring].*/i'
   'qstring_validation_pattern' '.'
         'select_record' 'templates/select_result.html'
   'select_header' 'templates/select_header.html'
   'popups' 'citylimits_popup.html'
  END
  TOLERANCE 0
     END
END ## end Map
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120926/c1af7853/attachment.html>
More information about the Geomoose-users mailing list
