[Geomoose-users] Make a floating legend
James Klassen klassen.js at gmail.com
Tue Apr 2 18:20:50 PDT 2013
A very long time ago we had a prototype with floating catalog control where
the map was full window with all floating controls. Unfortunately, that
didn't make it into the final cut and it is long gone.
Now, most of the user interface is handled using Dojo so if you wanted to
implement a custom control it would be easiest to work within Dojo.  This
falls into a rather advanced modification to GeoMoose so you will likely be
charting some of your own path.
On Apr 1, 2013 12:53 PM, "INDRA BAYU" <cucuberlian at gmail.com> wrote:
> hi everybody, i got something to ask you..
> I wanna build my custom legend that can trigger which layer that show
> in the map. The different is, that legend is floating on the map. So
> user can click and drag the position of the legend.
> First, I try to set the position of the legend with CSS but there's no
> change. My code is:
> ==============geomoose.html==================
> <div id="main">
>      <div id="middle" region="center">
>           <div id="map">
>                     <div id="mapContainer"></div>
>           </div>
>           <div id="control-panel" style="position:absolute;
> left:300px; top:300px;">
>                     <div id="tabs"></div>
>            </div>
>     <div>
> </div>
> the CSS code:
> <div id="control-panel" style="position:absolute; left:300px; top:300px;">
> can't make the legend floating on the map..
> is there any solution for this?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130402/6861aeca/attachment.html>
More information about the Geomoose-users mailing list
