[Geomoose-users] Possible to have a dropdown as a tool in toolbar?
Brent Fraser bfraser at geoanalytic.com
Wed Apr 3 09:18:44 PDT 2013
Bob,
   In 2.something (or earlier?) I did something similar by modifying the
geomoose.html to deliver a static list:
     <script type="text/javascript" src="custom/tour.js"></script>
     <div id="toolbar">
         <select
onChange="custom_tour(this.options[this.selectedIndex].value)"
style="width: 120px">
             <option value=""> Choose a Tour </option>
             <option value="Sample1"> Sample 1 </option>
         </select>
     </div>
And I did something similar in v2.4.   I instead coded a geomoose.php to
deliver most of the standard geomoose.html, but added a bit to query a
database and add entries to a select object:
         <select id="GA_SelectedImage"
onchange="GeoMOOSE.UX.registered_extensions.GA_ImageOps.prototype.zoomToImage(this.value);">
             <option value="">Choose Image:</option>
     while ($row = pg_fetch_array($result)) {
         if (!empty($image_id) && $image_id==$row['image_id']) {
           echo '<option selected="selected" value="'.$row['image_id'] .
":" . $row['extents'] . ":" . $row['path'] . '">' . $row['imagename'] .
"</option>";
         } else {
           echo '<option value="'.$row['image_id'] . ":" .
"</option>";
       print "\n";
         </select>
Best Regards,
Brent Fraser
On 4/3/2013 9:52 AM, Bistrais, Bob wrote:
> Thanks Brent.  I suppose this is possible, but the problem is, I'd
> like this to work for, among other things, picking a town name.  I
> have over 900 towns/townships that I would need to code in a list that
> way, so I'm not sure that's very feasible.
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Wednesday, April 03, 2013 11:38 AM
> *To:* Bistrais, Bob
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Possible to have a dropdown as a tool
> in toolbar?
> Bob,
>   As Jim points out, you could use a Drawer to execute your code:
> <drawer title="MyList" ...
>         <tool name="item1" title="item 1" type="javascript"
> selectable="false">
>  GeoMOOSE.UX.registered_extensions.my_extension.prototype.my_script('item1');
>         </tool>
>         <tool name="item2" title="item 2" type="javascript"
> selectable="false">
> GeoMOOSE.UX.registered_extensions.my_extension.prototype.my_script('item2');
>         </tool>
> or set the type='service', but I'm not sure how to pass the selected
> tool id to the service...
> And in either case, I don't think a multi-select would be possible.
> Best Regards,
> Brent Fraser
> On 4/3/2013 9:19 AM, Bistrais, Bob wrote:
>     Looking for something different.
>     The demo uses a "drawer" to contain related tools.  I'm looking
>     for something like an HTML pick list/combobox- select a value from
>     it, then do something with that value.  Although I could do this
>     as a service if need be, it would be nicer if I could have the
>     dropdown right on the toolbar.
>     *From:*Jim Klassen [mailto:klassen.js at gmail.com]
>     *Sent:* Wednesday, April 03, 2013 11:16 AM
>     *To:* Bistrais, Bob
>     <mailto:geomoose-users at lists.osgeo.org>
>     tool in toolbar?
>     Doesn't the demo do this with "Layer Tools"?  Or are you looking
>     for something different?
>     On Apr 3, 2013, at 10:00 AM, Bistrais, Bob wrote:
>     Is it possible to have a dropdown list as a tool in the GeoMoose
>     toolbar (version 2.6.x)?  If so, does anyone have a sample of how
>     to set that up?
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130403/92c66de9/attachment-0001.html>
More information about the Geomoose-users mailing list
