[Geomoose-users] Linking search results to templates
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Tue Apr 9 13:35:56 PDT 2013
Bob,
This is probably further than you want to go, but I would be inclined to build a folder watcher or listener script that watches the contents of a folder and adds any new content automatically to a Database for retrieving.  The process of adding the data to the database should also provide a semblance of validation as well.  Then the results are easy to query for, even in a double pass scenario, IE get ID in the view desired, then iterate through for those links attached to that ID, all handled via a SQL statement.  Easy to add to for may different files too.
Bobb
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
Sent: Tuesday, April 09, 2013 3:30 PM
To: Brent Fraser
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Linking search results to templates
Yes, I'm thinking of looking parsing the file names, concerned about search times, but need to give it a try.  The photo names are fairly consistent but not 100% so.
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, April 09, 2013 4:25 PM
To: Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
I'm always paranoid when it comes to data, so I prefer to have a step where I "load" the data and confirm the result.  But as long as the data is consistent (when does that happen?), maybe you could just modify the PHP to:
    1. get the contents of a directory where the photos are stored
    2. parse the file names
    3. and generate the output HTML.
Basically doing a "join" and template process in the PHP.  Might be a performance issue if there are thousands of photos in the dir....
Best Regards,
Brent Fraser
On 4/9/2013 2:11 PM, Bistrais, Bob wrote:
Thanks Brent,
Looks like most sites have 4 photos, but not all.  I'm finding cases of fewer or more than 4 photos.  Problem is, this could change as the customer adds more sites, or more photos to existing sites.  So I'd have to modify a table every time the customer sends data updates.  I was hoping maybe I could do this through MapServer templating?
Sent: Tuesday, April 09, 2013 3:57 PM
To: Bistrais, Bob
Bob,
  Depends on the data.  Are there usually 4 photos? If so, just create 4 columns in the Site table and populate them with the path to photos.  If it is more variable (sometimes 1, sometimes 5 photos), create a table to relate Sites to Photos:
SitePhotos
siteID:    photoPath:
and do a table join within Mapserver's Map file (in the LAYER's DATA statement) to relate sites to tables.
Best Regards,
Brent Fraser
On 4/9/2013 1:14 PM, Bistrais, Bob wrote:
I'm working on an application which depicts various sites (several thousand of them).  The customer has photos of the different sites, each site usually has 4 pictures, from different angles.  The spatial data does not have an attribute linking the photos to a particular record.  But each photo has the site ID as part of its name.  Example- Site 1234 has photos with names like "1234Front.jpg", "1234Rear.jpg", etc.
What I'd like to do is display search/query results so that the corresponding photos (actually, links to them) will appear in an Identify or query result tab.  I can form the URL's based on the site's ID number, but don't know how to insert these into the identify/query templates.
Has anyone done something similar to this, and would have any advice on how to do this?
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130409/f35ef669/attachment.html>
More information about the Geomoose-users mailing list
