[Geomoose-users] Linking search results to templates
Reynolds, Michael J. (DOT) mike.reynolds at state.mn.us
Tue Apr 9 13:35:42 PDT 2013
We moved all photos into a subfolder named using the site ID.
Made the process of finding relevant photos much quicker.
If your photos are high res, php and one of its image libraries can be used to check for an existing thumbnail and if there is not one, to create it. This thumbnail can increase the speed of the identify results but you take a hit the first time the photos are accessed.
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, April 09, 2013 08:25 PM
To: Bistrais, Bob <Bob.Bistrais at maine.gov>
Cc: geomoose-users at lists.osgeo.org <geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] Linking search results to templates
I'm always paranoid when it comes to data, so I prefer to have a step where I "load" the data and confirm the result.  But as long as the data is consistent (when does that happen?), maybe you could just modify the PHP to:
    1. get the contents of a directory where the photos are stored
    2. parse the file names
    3. and generate the output HTML.
Basically doing a "join" and template process in the PHP.  Might be a performance issue if there are thousands of photos in the dir....
Best Regards,
Brent Fraser
On 4/9/2013 2:11 PM, Bistrais, Bob wrote:
Thanks Brent,
Looks like most sites have 4 photos, but not all.  I’m finding cases of fewer or more than 4 photos.  Problem is, this could change as the customer adds more sites, or more photos to existing sites.  So I’d have to modify a table every time the customer sends data updates.  I was hoping maybe I could do this through MapServer templating?
Sent: Tuesday, April 09, 2013 3:57 PM
To: Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Bob,
  Depends on the data.  Are there usually 4 photos? If so, just create 4 columns in the Site table and populate them with the path to photos.  If it is more variable (sometimes 1, sometimes 5 photos), create a table to relate Sites to Photos:
SitePhotos
siteID:    photoPath:
and do a table join within Mapserver's Map file (in the LAYER's DATA statement) to relate sites to tables.
Best Regards,
Brent Fraser
On 4/9/2013 1:14 PM, Bistrais, Bob wrote:
I’m working on an application which depicts various sites (several thousand of them).  The customer has photos of the different sites, each site usually has 4 pictures, from different angles.  The spatial data does not have an attribute linking the photos to a particular record.  But each photo has the site ID as part of its name.  Example- Site 1234 has photos with names like “1234Front.jpg”, “1234Rear.jpg”, etc.
What I’d like to do is display search/query results so that the corresponding photos (actually, links to them) will appear in an Identify or query result tab.  I can form the URL’s based on the site’s ID number, but don’t know how to insert these into the identify/query templates.
Has anyone done something similar to this, and would have any advice on how to do this?
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130409/13ef21e1/attachment-0001.html>
More information about the Geomoose-users mailing list
