[Geomoose-users] GeoMOOSE 2.6.1 not displaying identify, select, or search results in IE / Chrome - does anyone know of a revision that works?
Boris Chitombo franticpianist at yahoo.co.uk
Mon Aug 5 16:42:48 PDT 2013
Hello,
I had had this issue as well after I updated my open layers to 2.13 I did some poking around and it appears to open layers have deprecated some functions that geomoose uses for the identify.
If I remember correctly it was getChildNodesValues() or a something similar. I fixed my issue by including the deprecated.js file from open layers which provides all the deprecated functions.
It is only a partial fix but it works.
Thanks
Boris
On Aug 6, 2013, at 3:10 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I was able to resolve this issue.
> I replaced many of the files in the \htdocs folder (which was based of trunk a couple weeks ago) with the ones from the original 2.6.1 download.  I suspect that the error has something to do with one of the javascript files in either the htdocs\build or the htdocs\geomoose folder.
> If this is the case that means that the trunk version could be broken.  One possible change I noticed is that openlayers changed from version 2.11 to 2.12.
> Thank you
> Mark Volz, GISP
> GIS Specialist
>> -----Original Message-----
>> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-
>> bounces at lists.osgeo.org] On Behalf Of Mark Volz
>> Sent: Monday, August 05, 2013 9:26 AM
>> To: geomoose-users at lists.osgeo.org
>> Subject: [Geomoose-users] GeoMOOSE 2.6.1 not displaying identify, select,
>> Hello,
>> I noticed that GeoMOOSE 2.6.1 does not seem to display identify, select, or
>> search results in IE or Chrome.
>> Questions:
>> 1)  Does anyone out there have a revision that does work?
>> 2)  Could anyone point me in the right direction to try to debug the error that
>> I am getting:
>> Message from webpage
>> Error Calling the server:
>> TypeError: Unable to get value of the property 'length': object is null or
>> undefined.
>> Thanks for any help
>> Mark Volz, GISP
>> GIS Specialist
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
