[Geomoose-users] no search results in some cases when the field value contains spaces -- GM 2.6.1
Bistrais, Bob Bob.Bistrais at maine.gov
Tue Aug 6 09:04:50 PDT 2013
Hi Mark,
I seem to remember something like this, looking back in the old code to see if I can find anything.  In the meantime, maybe using Firebug or similar tool, see what your input value looks like- maybe there's a %20 or other delimiter causing the search to fail.
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Tuesday, August 06, 2013 11:48 AM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] no search results in some cases when the field value contains spaces -- GM 2.6.1
Hello,
I created an address search in GeoMOOSE and I noticed that the search does not work as expected.  I suspect that GeoMOOSE has trouble searching when the values have spaces in them.  Has anyone else noticed this behavior?
For example:
Matches exactly search:
	18.645.3840  - works
	421 2ND AVE  SE  - does not work
Contains Search
	8.645.3840  - works
	21 2ND AVE  S  - works
Begins with search
	18.645  - works
	421 2ND  -does not
In List search  - not tested.
Thanks
Mark Volz, GISP
GIS Specialist
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
