[Geomoose-users] Trouble creating PDF templates
Bistrais, Bob Bob.Bistrais at maine.gov
Fri Aug 9 08:44:34 PDT 2013
Great ideas from everyone!  Looks like I got it to work with a combination of advice- I used ArcMap to make the template, PrimoPDF to output it, and I also found that the output was cranked up to 600dpi, reducing it helped my situation as well.
I like the idea of using a properly formatted HTML page, just need to brush up on my CSS a little more.
Thanks everyone!
Bob
From: Brian Fischer [mailto:bfischer at houstoneng.com]
Sent: Friday, August 09, 2013 9:43 AM
To: Mark Volz; eadam at co.lincoln.or.us; Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org
Subject: RE: [Geomoose-users] Trouble creating PDF templates
Bob, I have been using ArcMap to create that template PDF and it seems to work fine.  Maybe it's something with fpdf and Word.
I do agree with Mark that fpdf might be a bit dated and maybe there are better options to consider in the future.  Another option would be to get rid of the PDF creation and just use a html page that is formatted to be printable.  Most people have options these days to print to pdf from their browser.
Brian Fischer
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | F 763.493.5572
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Thursday, August 08, 2013 4:07 PM
To: eadam at co.lincoln.or.us<mailto:eadam at co.lincoln.or.us>; Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] Trouble creating PDF templates
Hello,
In the past I think I had success using primo pdf to create the template.  However that was a while ago so things could have changed...
Lyon County, MN
(507) 532-8218
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Eli Adam
Sent: Thursday, August 08, 2013 3:25 PM
To: Bistrais, Bob
On Thu, Aug 8, 2013 at 12:50 PM, Bistrais, Bob <Bob.Bistrais at maine.gov<mailto:Bob.Bistrais at maine.gov>> wrote:
I'm trying to modify the default PDF printing templates for GM 2.6.1, adding my own agency logo.  I do the process by making a copy of the template into Word, make the modifications, them use Word's Save As Adobe PDF function to save it back as a PDF file.
When I attempt to use it, I find an error in Firebug:
<b>FPDF error:</b> Unable to find xref table.
This sounds like an error from the underlying pdf library.  It seems that your pdf has some feature that is not supported by fpdf.  Try taking the pdf you made and running it through a pdf printer or otherwise converting it to pdf with a different method.
HTH, Eli
I've followed the GM documentation and think I was doing it correctly.  Suggestions?
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130809/997867d6/attachment-0001.html>
More information about the Geomoose-users mailing list
