[Geomoose-users] Trouble selecting on line layer
Bistrais, Bob Bob.Bistrais at maine.gov
Thu Aug 22 07:12:48 PDT 2013
Problem solved-
Didn't have the select_record template set in the line layer.
It had nothing to do with the fact it was line features.
Sent: Wednesday, August 21, 2013 6:04 PM
To: geomoose-users at lists.osgeo.org
Subject: Trouble selecting on line layer
I am having some trouble getting the select service to work with a line layer, GM 2.6.1.  I put the debug on the mapfile but the only error I sometimes get is no results.  I adjusted the search tolerance to a generous 30m.  Now I get a popup which says error calling the server, unable to load php/select.php status:500.
This service works fine with a polygon layer, but for this project I need it to work with a line layer.  Any ideas?  Shall I attach any code?
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130822/8ab7bc73/attachment.html>
More information about the Geomoose-users mailing list
