[Geomoose-users] agg driver
Carlo Pelliconi c.pelliconi at sis-ter.it
Sat Feb 23 06:04:03 PST 2013
Hi James.
This is last update about my problem, or better OLD problem: with
Mapserver 6 (from testing repository) all works fine, no more AGG problem.
So the resulting working configuration is this:
Debian stable Squeeze
Apache 2.2.16
PHP 5.4.4 (from testing Wheezy)
Mapserver 6.0.1 (from testing Wheezy) + PHPMapscript (package
php5-mapscript from stable Squeeze)
GeoMOOSE 2.6.1
Thank you very much for your really useful help.
With Best Regards
Carlo
Il 22/02/2013 17:13, James Klassen ha scritto:
> I don't know what is wrong with AGG in your particular case, but I
> would suggest going with MapServer 6 or newer anyway.
> All the installs I have done used a MapServer that was compiled from
> source.  Also, the Debian PHP was missing a module (I can't remember
> which one right now and it may not be needed anymore for GeoMoose
> 2.6.  So rebuilding php from the deb was also necessary.  Duck do you
> remember???)
> http://www.geomoose.org/docs/install_unix.html
> Anyway,
> apt-get build-dep mapserver
> Will pull in all the dependencies and then building MapServer from
> source is rather painless.
> Also, you can have MapServer 6 and 5.6.5 (or any version) installed on
> the same machine if you install to different prefixes.
> On Feb 22, 2013 2:19 AM, "Carlo Pelliconi" <c.pelliconi at sis-ter.it
> <mailto:c.pelliconi at sis-ter.it>> wrote:
>     Has anyone installed cgi-mapserver 5.6.5-2+squeeze2 with
>     php5-mapscript on debian squeeze with aptitude, and then used with
>     geomoose 2.6?
>     I've done, and all seems good (mapserv -v), but in Geomoose It
>     seems not recognizing agg driver.
>     And now? What's the best way for solving the situation?
>     Thank you
>     Carlo
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130223/26fe2424/attachment.html>
More information about the Geomoose-users mailing list
