[Geomoose-users] coordinates showed in footer section
Alejandro Garcia alegarmen at gmail.com
Mon Jan 14 01:23:36 PST 2013
Hi James, thanks a lot for your fast reply, it has been very useful
I forgot the Google Satellite layer can not be reprojected, so my own
layers are in the correct position with the correct coordinates, but Google
layer was showed in a wrong way.
Following the same subjet, in the file setting.ini there is a projection
label fill with EPSG3857, how does work this label?
thanks in advance
2013/1/11 James Klassen <klassen.js at gmail.com>
> The coordinates display in the same projection as the map is drawn in.
>  (Although this wouldn't necessarily have to be the case, but I don't
> believe anyone has requested otherwise yet.)
> Given that, it sounds like you may have skipped Step 4 (Updating
> <configuration> in the mapbook).
> Note: if you don't display in 3857/900913 you cannot use the common
> commercial tile sources for basemaps.
> On Fri, Jan 11, 2013 at 4:43 AM, Alejandro Garcia <alegarmen at gmail.com>wrote:
>> Hello to all,
>> I'm starting to prepare a map web viewer based on geomoose 2.6. All my
>> data are in EPSG:32628, that is, UTM28N and WGS84. I followed the
>> instruccions I found here (http://www.geomoose.org/docs/projections.html),
>> but it doesn't work, I can see maps but not in the correct position by far.
>> The aplication seems work always in EPSG:3857. I've seen even in the live
>> demo (http://www.geomoose.org/demo/geomoose.html) coordinates showed are
>> under EPSG:3857 specifications instead do it in EPSG:26915.
>> As you can imagine, show the coordinates in our reference system is very
>> important.
>> What I'm doing wrong? any help?
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130114/ec7b566f/attachment.html>
More information about the Geomoose-users mailing list
