[Geomoose-users] coordinates showed in footer section
Mark Volz MarkVolz at co.lyon.mn.us
Mon Jan 14 14:00:48 PST 2013
Jim,
At one time I thought it would be worthwhile to display coordinates on the bottom in different system than the map.  One use case would be to draw a map using UTM 15 so I could take better advantage of the high speed state WMS server, while displaying coordinates in a county system that users care about.
Mark Volz
GIS Specialist
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of James Klassen
Sent: Friday, January 11, 2013 9:59 AM
To: Alejandro Garcia
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] coordinates showed in footer section
The coordinates display in the same projection as the map is drawn in.  (Although this wouldn't necessarily have to be the case, but I don't believe anyone has requested otherwise yet.)
Given that, it sounds like you may have skipped Step 4 (Updating <configuration> in the mapbook).
Note: if you don't display in 3857/900913 you cannot use the common commercial tile sources for basemaps.
On Fri, Jan 11, 2013 at 4:43 AM, Alejandro Garcia <alegarmen at gmail.com<mailto:alegarmen at gmail.com>> wrote:
Hello to all,
I'm starting to prepare a map web viewer based on geomoose 2.6. All my data are in EPSG:32628, that is, UTM28N and WGS84. I followed the instruccions I found here (http://www.geomoose.org/docs/projections.html), but it doesn't work, I can see maps but not in the correct position by far. The aplication seems work always in EPSG:3857. I've seen even in the live demo (http://www.geomoose.org/demo/geomoose.html) coordinates showed are under EPSG:3857 specifications instead do it in EPSG:26915.
As you can imagine, show the coordinates in our reference system is very important.
What I'm doing wrong? any help?
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130114/a41a4580/attachment.html>
More information about the Geomoose-users mailing list
