[Geomoose-users] WMS not working
Dennis Tumberg dtumberg at invergroveheights.org
Wed Jul 3 13:39:09 PDT 2013
Sorry, "Nothing worked" was just meaning changing the status did not make any changes to what I was seeing, the layer still did not display, but everything else that I have in is still working the same as before.
I have made changes to the demo and have many layers from the city showing in the GeoMOOSE site, I just projected them to UTM coordinates to make them work.  I have gone back and forth on whether to keep the site in the original Web Mercator coordinates or to go with Dakota County coordinates, the only reason I would stay in Web Mercator coordinates is to have the yahoo basemap still useable, but I would have to project all the files each time I do any updates since everything at the city is stored in Dakota County Coordinates.  Any thoughts on which one will work better in the long run?
Sent: Wednesday, July 03, 2013 3:22 PM
To: Dennis Tumberg
Cc: geomoose-users at lists.osgeo.org List
Subject: Re: [Geomoose-users] WMS not working
Let's take a step back...  "Nothing worked" doesn't give us much of a base line to help you from.
Do you have the stock 2.6.1 demo working?
What have you changed from the demo?
            Simplest would be to add the fsa2010 layer to the lmic.map file, then add the layer child to the map-source, and finally add the layer in the catalog.
            Have you tried to change the projection of the map from Web Mercator (3857) to UTM15 (26915)?  If so, you should be aware that the popular tiled layers (google, bing, osm, ...) won't work anymore, but as you are in Dakota County, there should be a good basemap available to you in 26915 that you could use instead.  Also, if you change projection, the max_extent, initial_extent, zoom_tos, will need to change to the new projection.  You may also want to look at changing numZoomLevels and maxResolution.
What does not working mean?
            Pink map?
            White map?
            No interface?
            And error messages? (And check in a JavaScript console too, like Firebug)
            Do other layers work?
The statewide fsa2010 layer from MNGeo isn't significantly different than the met10 layer that is in the demo already.
On Jul 3, 2013, at 3:01 PM, Dennis Tumberg wrote:
Sorry, I had copied that to post it, but switched it to "on" before I posted, nothing worked.  I deleted status all together, it is still not working.
Dennis Tumberg
GIS Technician
City of Inver Grove Heights
Phone - 651.554.3446
From: Paul Wickman [mailto:paul at flatrockgeo.com]
Sent: Wednesday, July 03, 2013 2:57 PM
To: Dennis Tumberg
Cc: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Dennis,
At first glance, try removing the ' status="off" ' setting on the <layer>
On Wed, Jul 3, 2013 at 2:23 PM, Dennis Tumberg <dtumberg at invergroveheights.org<mailto:dtumberg at invergroveheights.org>> wrote:
I have been working with GeoMOOSE just a short time and am having issues with getting a WMS layer to display.
I have tried adding the WMS directly with and without a MAP file.
Here is what I have for the map source and layer in catalog:
<map-source name="fsa2010" type="wms" projection='EPSG:26915'>
                <url>http://geoint.lmic.state.mn.us/cgi-bin/wms?</url>
                 <layer name="fsa2010" status="off"/>
                <param name="TRANSPARENT" value="true"/>
                <param name="FORMAT" value="image/png"/>
</map-source>
<layer title="2010 FSA" src="fsa2010/fsa2010" status="off" legend="false" fade="false" unfade="false"/>
What am I doing wrong, I can't seem to find any of the solutions with online searches.
Thanks,
Dennis Tumberg
GIS Technician
Phone - 651.554.3446<tel:651.554.3446>
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
Paul Wickman
CTO | Flat Rock Geographics
612.280.5850 | paul at flatrockgeo.com<mailto:paul at flatrockgeo.com>
www.flatrockgeo.com<http://www.flatrockgeo.com/> | twitter.com/flatrockgeo<http://twitter.com/flatrockgeo>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130703/9f5eeb0d/attachment.html>
More information about the Geomoose-users mailing list
