[Geomoose-users] Unsupported output format (image/png;bits=8)
Brent Fraser bfraser at geoanalytic.com
Wed Jul 24 06:31:02 PDT 2013
It might be the IMAGEMODE RGBA   (this implies 32 bit output) combined
with the MIMITYPE "image/png; mode=8bit" (which defines 8 bit output) .
But the fact that error message states "bits=8", which is not the
correct syntax for the MIMETYPE, suggests you need to dobule check you
are using the mapfile with the correct syntax (mode=8bit).
Best Regards,
Brent Fraser
On 7/24/2013 7:03 AM, Robert R. Raiz wrote:
> I read all day about the outputs and it seems that it should display
> everything ok even if I do not specify the outputformat.
> Everything I modify returns /"msWMSLoadGetMapParams(): Image handling
> error. Unsupported output format (image/png;bits=8)"/
> Is it possible ?! to come from the following part:
> WEB
> METADATA
> 'ows_title' 'Parcel Maps'
> 'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:4269 EPSG:2277'
> 'ows_enable_request' '*'
> 'ows_onlineresource' 'http://www.geomoose.org'
> END
> END
> I did not use this before and I wonder if the MIMTYPE is somehow
> returned all the time as png 8 bit. If I remove this part, again, I
> get an error.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130724/8d5c77d1/attachment.html>
More information about the Geomoose-users mailing list
