[Geomoose-users] Unsupported output format (image/png;bits=8)
Robert R. Raiz raizrobert at gmail.com
Wed Jul 24 07:02:25 PDT 2013
Thank you Brent,
Unfortunately, I still get that error even with your settings.
I am using 6.2.1. It appears like it is hardcoded somewhere, dunno. The
mapfile is quite straightforward, no complicated stuff. The only version
which works (but does not display png icons well) is the one from the first
emails. Did not see this type of errors before. Strange.
On Wed, Jul 24, 2013 at 4:53 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Here's the definition I appear to be using:
>     IMAGETYPE AGG_PNG
>     OUTPUTFORMAT
>         NAME  'AGG_PNG'
>         DRIVER AGG/PNG
> #        MIMETYPE "image/png;mode=24bit"
>         MIMETYPE "image/png"
>         IMAGEMODE RGBA    # renders IMAGECOLOR transparent
>         EXTENSION "png"
>         FORMATOPTION "INTERLACE=false"
>         FORMATOPTION "TRANSPARENT=ON"
>         TRANSPARENT ON
>         FORMATOPTION "QUANTIZE_FORCE=ON"
>         FORMATOPTION "QUANTIZE_DITHER=off"
>         FORMATOPTION "QUANTIZE_COLORS=256"
>     END
> Which version of Mapserver are you using?
> Best Regards,
> Brent Fraser
> On 7/24/2013 7:37 AM, Robert R. Raiz wrote:
> I just tried it out. Both:
>  WEB
>  METADATA
>  'ows_title' 'Parcel Maps'
>  'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:4269 EPSG:2277'
>  'ows_enable_request' '*'
>  'ows_onlineresource' 'http://www.geomoose.org'
>  END
>  END
>  OUTPUTFORMAT
>   NAME "png8"
>   DRIVER AGG/PNG8
>   MIMETYPE "image/png; mode=8bit"
>   IMAGEMODE RGB
>   EXTENSION "png"
>  END
>  And:
>         OUTPUTFORMAT
>   NAME "png32"
>   DRIVER AGG/PNG
>   MIMETYPE "image/png; mode=32bit"
>   IMAGEMODE RGBA
>   EXTENSION "png"
>  END
> Both return the same error. I think the syntax is quite ok, I do not see
> what could be wrong as there are a few simple lines.
> If I put DRIVER AGG/PNG32 is returns another error: loadOutputFormat():
> General error message. OUTPUTFORMAT clause references driver AGG/PNG32, but
> this driver isn't configured.
*Raiz Roland Robert*
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130724/b3c28ce7/attachment-0001.html>
More information about the Geomoose-users mailing list
