[Geomoose-users] Public facing GeoMoose sites as examples.
Solly Vuso sollyvuso at gmail.com
Mon Jul 22 05:04:09 PDT 2013
Hi Ed
I am not winning and I am not giving up, i get lost on the MAPBOOK.XML. I
have attched my new mapfile and the shapefile. I have used Qgis to create a
mapfile. The only problem i have is that  shapefile doesn't fall where i
want it to be (may be the problem is Mapbook
Thank you
On Wed, Jul 17, 2013 at 5:36 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:
> Solly,****
> My name is Ed not Bob.****
> When I first started using Geomoose I would take baby steps in modifying
> the working version, the steps below may help you in getting started using
> your own data. After each step test Geomoose and see if it is still working.
> **1.       **Copy Geomoose folder to somewhere else, so you can restore
> the original files if something goes wrong.****
> **2.       **Configure Geomoose to zoom to your area of extents and
> setting the background to your Google layer of choice.****
> **3.       **Copy the Parcels MAP file and rename it****
> **4.       **Modify new MAP file contents to suit your needs****
> **a.       **EXTENT****
> **b.      **UNITS****
> **c.       **PROJECTION ****
> **d.      **LAYER -> NAME****
> **e.      **LAYER -> DATA****
> **f.        **LAYER -> TYPE****
> **5.       **Refer to http://geomoose.org/howto/layer.html for the items
> below****
> **6.       **In MAPBOOK.XML, copy the map-source section for the parcels
> layer and rename it****
> **7.       **In MAPBOOK.XML, in the layer catalog section copy the
> parcels layer and rename it****
> Ed****
> *From:* Solly Vuso [mailto:sollyvuso at gmail.com]
> *Sent:* Wednesday, July 17, 2013 7:11 AM
> *To:* Ed Boesenberg
> *Subject:* Re: [Geomoose-users] Public facing GeoMoose sites as examples.*
> Hi Bob****
> My projection is WGS 84 and I will attach a shapefile .****
> I will be using google as a background and I have tried to use Qgis to
> create  a mapfile using the data I sent to you as a test but I dont know
> where to change inside geomoose folders in order to view my data being
> overlapped with Google****
> Thank you again for responding to my emails ****
> On Tue, Jul 16, 2013 at 4:36 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:*
> Solly,****
> The Geomoose website has documentation on it to help you get started, see
> the following pages.****
> http://geomoose.org/docs/projections.html****
> http://geomoose.org/howto/layer.html****
> What projection is your data?****
> What will you be using as a background? Google, Bing, etc.****
> What format is your data?****
> Ed****
> *Sent:* Monday, July 15, 2013 5:12 PM
> *To:* Ed Boesenberg
> *Subject:* RE: [Geomoose-users] Public facing GeoMoose sites as examples.*
> Hi Bob****
> Not yet , am still not sure where to  start .please help ****
> Thank u ****
> On 15 Jul 2013 5:37 PM, "Ed Boesenberg" <boesiii at yahoo.com> wrote:****
> Solly,
> Did you ever get your Geomoose working with your own data?
> Ed
> -----Original Message-----
> From: sollyvuso at gmail.com [mailto:sollyvuso at gmail.com]
> Sent: Thursday, July 11, 2013 8:17 AM
> To: boesiii at yahoo.com
> Subject: Re: [Geomoose-users] Public facing GeoMoose sites as examples.
> HI Bob
> I am Solly and am new in Geomoose, I saw the below email and I thought you
> the right person to help me, I want to use my own data but I dont know
> where
> to start . I have configured the geomoose and its working
> <quote author='boesiii'>
> Bob,
> A client of mine, who is a water and sewer authority, has a GM 2.4 setup
> but
> unfortunately it is not a public facing. I put together a GeoMoose
> application to keep track of all their water and sewer information which
> includes, as-built drawings, sanitary sewer videos, pipe sizes,invert
> elevations, etc.  I could provide a screen shot if needed.
> Ed
> http://geomoose-users.964460.n3.nabble.com/Geomoose-users-Public-facing-GeoM
> oose-sites-as-examples-tp3741982p3742337.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> </quote>
> Quoted from:
> http://osgeo-org.1560.x6.nabble.com/Geomoose-users-Public-facing-GeoMoose-si
> tes-as-examples-tp4929506p4929507.html
> _____________________________________
> Sent from http://osgeo-org.1560.x6.nabble.com****
> Best Regards
> Solly Vuso
> Cell:073 3068 170
> Fax:086 555 1270
> I may not know what tomorrow holds for me but I do know who holds ma
> tomorrow..... ****
Best Regards
Solly Vuso
Cell:073 3068 170
Fax:086 555 1270
tomorrow.....
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130722/01a32f1c/attachment-0001.html>
Type: application/rar
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130722/01a32f1c/attachment-0001.rar>
More information about the Geomoose-users mailing list
