[Geomoose-users] Dealing with scales
Robert R. Raiz raizrobert at gmail.com
Wed Jun 26 05:30:58 PDT 2013
Back again,
Just a follow-up on the topic.
I tried your method and indeed it works (it worked even before, without
having the EPSG2263.js file but now I think it renders the features faster);
Thanks for the tip and I will post a new topic as my next question is
slightly off this subject.
On Thu, Jun 20, 2013 at 5:15 PM, Jim Klassen <klassen.js at gmail.com> wrote:
> You probably need to create the projection definition.
> in ...wherever geomoose is.../htdocs/projections
> create a EPSG2263.js file with the following line in it:
> Proj4js.defs["EPSG:2263"] = "+proj=lcc +lat_1=41.03333333333333
> +lat_2=40.66666666666666 +lat_0=40.16666666666666 +lon_0=-74
> +x_0=300000.0000000001 +y_0=0 +ellps=GRS80 +datum=NAD83
> +to_meter=0.3048006096012192 +no_defs";
> Then add the EPSG2263.js file to geomoose.html and geomoose_dev.html (next
> to or replace the one for EPSG26915)
> On Jun 20, 2013, at 8:54 AM, Robert R. Raiz wrote:
> Hello Jim,
> In the mapbook I have the following params:
>             *<param name="projection">EPSG:2263</param>*
> * <param name="max_extent">1115163,61542,1581609,527988</param> *
> * <param name="initial_extent">1115163,61542,1581609,527988</param>*
> * <param name="always_scroll_zoom">true</param>*
> * <param name="measure_tool.show_area_segments">false</param>*
> * <param name="layer_controls.metadata.on">false</param>*
> * <param name="group_checkboxes">true</param>*
> * <param name="default_tab">Catalog</param>*
> * <param name="ground_units">ft</param>*
> * <param name="maxResolution">156543.03390625</param>*
> * <param name="numZoomLevels">20</param>*
> * <param name="reference_map.enabled">false</param>*
> * <param name="coordinate_display.usng">true</param>*
> * <param name="fractional_zoom">true</param>
> *I added the *<param name="ground_units">ft</param>* following your
> advice and it is almost perfect (1:43157 GeoMoose and 1:448286 Chameleon);
> One thing I noticed in Firebug. Although I can see the layers, I get two
> errors (atually, one - 2 times):
> *GET EPSG2263.js 404 NotFound
> (/geomoose/libs/proj4js/lib/defs/EPSG2263.js was not found on this server)
> On Thu, Jun 20, 2013 at 4:13 PM, Jim Klassen <klassen.js at gmail.com> wrote:
>> It looks like CONFIGURATION.ground_units is simply being passed into
>> OpenLayers as OpenLayers.Map.units.  The scale combo-box is using
>> OpenLayers.Map.getScale.
>> The OpenLayers page [1] says it supports feet, but indicates the
>> parameter is only used if it is not defined in the projection.  What
>> projection do you have set in the configuration section of your mapbook?
>>  Alternatively, what do the following three lines output from Firebug (or
>> other javascript console) while viewing your GeoMoose site?
>> Map.getProjection();
>> Map.units;
>> Map.getProjectionObject().proj.units;
>> Digging up my old county coordinates example... Proj4js doesn't seem to
>> recognize units=sft.  Map.units = "m" and proj.units = "null".  If I set:
>> Then Map.units="ft" and the initial scale changes from 1:6933504 with
>> meters to 1:2113331 with feet (a factor of ~ 3.28 which is what would be
>> expected).
>> [1]
>> http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html#OpenLayers.Map.units
>> On Jun 20, 2013, at 2:46 AM, Robert R. Raiz wrote:
>> Hello all,
>> Did some more research on this and I would point out a few aspects.
>> I tested with the demo files and there, it all seems ok. The thing is, in
>> the demo shapefile, we have the data in meters and so is the mapbook.xml
>> file configured. eg: *<param name="ground_units">m</param>*.
>> All my shapes, projections, all the data I have is in feet. I guess this
>> is the problem as I don't think there is a ground_units param for feet
>> (only *‘m’, ‘in’, ‘mi’, ‘dd’*).
>> The only place where I found something related to feet was in the
>> \geomoose\htdocs\php\print.php file which deals with the print option:
>> *if($ground_units == 'ft') {*
>> * $inches_per_unit = 12.0;*
>> Really close to the difference I gave as an example in my first post (1:448286
>> - Chameleon and in GeoMoose I have 1:35203 for the same extent);
>> 448286/35203 =~ 12,7
>> As I am not a developer (but would like to be sometime in the future), I
>> would need some guidelines as to where I could add/modify/update the
>> ground_unit param (eg: *<param name="ground_units">ft</param>*) so
>> GeoMoose could treat correctly the feet unit of measurement and have a
>> correct scale. I think it would be a huge enhancement for this to be
>> supported as especially US data is kept mostly in projections using feet.
>> I really appreciate all the feedback received,
>> On Wed, Jun 19, 2013 at 9:30 PM, James Klassen <klassen.js at gmail.com>wrote:
>>> I second that.  Even feet vs meters should only be a factor of 3.  My
>>> experience is GeoMoose scales are close to but not exactly the same as
>>> MapServer scales (when DPI is left as defaults).  I haven't tried a site
>>> using feet lately, but I know it used to work (the first GeoMoose site was
>>> in feet.)
>>> I'm sorry I am too swamped right now to dig into this further at the
>>> moment.  Hopefully someone else on the list can help you more.
>>> On Jun 19, 2013 11:07 AM, "Brent Fraser" <bfraser at geoanalytic.com>
>>> wrote:
>>>>  Since the difference in the reported scale between Chameleon and
>>>> Geomoose is over an order of magnitude, I suspect there is a units
>>>> mis-configuration somewhere.  Just where depends on which reported scale is
>>>> closer to what's expected...
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 6/19/2013 9:37 AM, Robert R. Raiz wrote:
>>>> Hello James,
>>>> Well, yes, actually for me it is important to know that the  MINSCALE /
>>>> MAXSCALE from map files will be read accordingly in GeoMoose. I need the
>>>> correspondence between them to be correct and to be able to check the
>>>> correct rendering of features.
>>>> I tested today and it seems what I have in the lower right part
>>>> (GeoMoose) is not quite ok compared to what I have in the mapfile (I am
>>>> only referring to scale here);
>>>> To sum up, seeing the big difference between the scales in Chameleon
>>>> and GeoMoose at the same extent, I do not understand how this could work.
>>>> To give a short eg: I have a class rendered in the mapfile between MINSCALE
>>>> 2000 and MAXSCALE 6000. How can see this range (class) in GeoMoose if I
>>>> cannot rely on the scale in the bottom right corner.
>>>> Hope I am not missing something here :)
>>>> On Wed, Jun 19, 2013 at 6:08 PM, James Klassen <klassen.js at gmail.com>wrote:
>>>>> Not really since the browsers don't accurately report screen DPI, so
>>>>> traditional scales in the interactive map are rather meaningless.  The main
>>>>> place the scale is important is to allow printing to a known scale.
>>>>> Assuming GeoMoose's DPI matches MapServer's (and I think it is at least
>>>>> close), it also helps when setting min/max scale denominators in MapServer
>>>>> layers/classes.
>>>>> The scale reported in the interface (in the drop down in the lower
>>>>> right) is a scale assuming some nominal display DPI.  (Either 72, 75 or 96
>>>>> I think, but would have to check to be sure.)
>>>>> The scales parameter in the mapbook is actually a resolution.  (It is
>>>>> simply passed into OpenLayers to setup the zoom levels, primarily for the
>>>>> popular tiled basemaps.)
>>>>>  On Jun 19, 2013 9:41 AM, "Robert R. Raiz" <raizrobert at gmail.com>
>>>>> wrote:
>>>>>>  Oh, as usual, I find something right after I post..
>>>>>> I read that "The scales are actually ground units per pixel
>>>>>> resolution settings and not true scales. "
>>>>>> Is it possible to somehow change this to render actual scales?
>>>>>> On Wed, Jun 19, 2013 at 5:33 PM, Robert R. Raiz <raizrobert at gmail.com
>>>>>> > wrote:
>>>>>>> Hello all,
>>>>>>> As I said in a previous post, I am trying to replace the old
>>>>>>> Chameleon web mapping tool with GeoMoose.
>>>>>>> Something that I did not quite understand, is why the scales are
>>>>>>> different in these two mapping tools if they have the same extent;
>>>>>>> So, I have an extent in the mapfile. Chameleon is giving me a scale
>>>>>>> of 448286 and in GeoMoose I have 1:35203
>>>>>>> Can you please tell me what am I missing? I first thought that it
>>>>>>> has something to do with the ground_units param (as I need the units in
>>>>>>> feet);
>>>>>>> Thank you,
>>>>>>> *Raiz Roland Robert*
>>>>>>  _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130626/442f92d8/attachment-0001.html>
More information about the Geomoose-users mailing list
