[Geomoose-users] Who here is still supporting IE7?
Mark Volz MarkVolz at co.lyon.mn.us
Fri May 3 06:25:21 PDT 2013
Dan,
In my opinion everyone that uses IE should be on IE 8 or above.  I don't think that you and the other developers should waste a lot of time dealing with quirks from old browsers.  But for those that are still running an old version of IE, perhaps GeoMOOSE could display a pop up window that invites users to upgrade IE, or redirect them to an older version of GeoMOOSE that does support IE 6-7.
Mark
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Dan Little
Sent: Friday, May 03, 2013 7:50 AM
To: GeoMOOSE Users List
Subject: [Geomoose-users] Who here is still supporting IE7?
FOSS4G/NA will allow for us to do some direction planning and legacy browser support is a subject upon which I intend to tackle this year.  Legacy support with IE is causing us problems with IE10. Some of the feature-sniffing code in IE10 makes things *very* difficult and newer versions of our base libraries that support IE10 tend to break IE6/7/FF<3.6.
http://gs.statcounter.com/#browser_version_partially_combined-US-monthly-201302-201304-bar
If you value GeoMOOSE simply BECAUSE of IE6/7 support then we'll need to hear from you.  Another motivating factor: I cannot seem to *buy* a version of Windows that will run IE7 anymore.  My only functioning windows install is Win7 and I believe I've got it upgraded to IE10 at this point, for testing purposes.  I'm going to try and setup a down-grade VM for IE9 testing along with some automation.
Thanks all for any feedback.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130503/edf3f5e5/attachment.html>
More information about the Geomoose-users mailing list
