[Geomoose-users] GeoMOOSE Demo application - Can't find a way to display my layers -reg.
Jaisen Nedumpala jaisuvyas at gmail.com
Thu May 9 23:03:57 PDT 2013
I am Jaisen, new to GeoMOOSE.
I was trying to make up my data with GeoMOOSE. As I am new, I did only
minor changes in the demo application, as described in the documentation
"How To Add Layers". But I couldn't visualise my data in GeoMOOSE. I don't
understand where lies the problem. Please help me. What I did is described
below:
Created /var/www/geo/geomoose-2.6.1/htdocs/projections/EPSG32643.js with
content following:
Proj4js.defs["EPSG:32643"] = "+proj=utm +zone=43 +ellps=WGS84 +datum=WGS84
+units=m +no_defs +towgs84=0,0,0";
Created /var/www/geo/geomoose-2.6.1/htdocs/projections/EPSG4326.js with
content following:
Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84 +datum=WGS84
In /var/www/geo/geomoose-2.6.1/htdocs/geomoose.html
Added following as line 59 and 60:
<script type="text/javascript" src="projections/EPSG32643.js"></script>
<script type="text/javascript" src="projections/EPSG4326.js"></script>
In
/var/www/geo/geomoose-2.6.1/maps/demo/statedata/basemap.map
/var/www/geo/geomoose-2.6.1/maps/demo/parcels/parcels.map
/var/www/geo/geomoose-2.6.1/maps/demo/wms/lmic.map
/var/www/geo/geomoose-2.6.1/maps/demo/wms/usgs.map
Added
EPSG:32643 EPSG:4326
for 'ows_srs' parameter in METADATA section.
Created directory /var/www/geo/geomoose-2.6.1/maps/edavaka/landuse/
placed landuse.map in it.
Added following lines as line 100-104 to
/var/www/geo/geomoose-2.6.1/conf/mapbook.xml
<map-source name="Landuse" type="mapserver">
        <file>./edavaka/landuse/landuse.map</file>
        <layer name="landuse" status="on"/>
        <param name="FORMAT" value="image/png;bits=8"/>
    </map-source>
Added following lines as 387-391 to
            <group title="Panchayat Layers" expand="false">
                <layer title="Land use" src="Landuse/landuse"
metadata="true" legend="true" tip="Land use and land cover"
show-legend="true">
                <metadata>http://www.geomoose.org/docs/</metadata>
                </layer>
            </group>
Content of landuse.map is follows:
MAP
    NAME 'landuse'
    SIZE 800 650
    STATUS ON
    EXTENT  600200.710627 1297963.898875 614053.022957 1305268.779057
    UNITS METERS
    INCLUDE "../../geomoose_globals.map"
    WEB
        METADATA
            'ows_title' 'Land use Map'
            'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:3857
EPSG:32643 EPSG:4326'
            'ows_enable_request' '*'
            'ows_onlineresource' 'http://www.geomoose.org'
        END
    END
    PROJECTION
        'init=epsg:4326'
    END
    LEGEND
          STATUS ON
          LABEL
        TYPE TRUETYPE
        FONT vera_sans
        SIZE 8
        COLOR 0 0 0
          END
    END
      LAYER
        NAME landuse
            CONNECTIONTYPE postgis
            CONNECTION "dbname='mydb' host=localhost port=5432
user='jaisen' password='mypassword' sslmode=allow"
            DATA 'the_geom FROM "landuse" USING UNIQUE gid USING srid=4326'
            STATUS ON
        TYPE POLYGON
        LABELITEM 'PIN'
        LABELCACHE ON
        LABELMAXSCALE 20000
        FILTER ([PARC_CODE] == 1)
        CLASS
            NAME 'Landuse'
            STYLE
                WIDTH 3
                COLOR -1 -1 -1
                OUTLINECOLOR 93 181 53
                MAXSCALEDENOM 15000
            END
            STYLE
                SIZE 1
                COLOR -1 -1 -1
                OUTLINECOLOR 33 106 43
            END
            LABEL
                TYPE TRUETYPE
                FONT vera_sans
                SIZE 8
                ANTIALIAS TRUE
                COLOR 0 0 0
                OUTLINECOLOR 254 254 200
                BUFFER 4
                MINFEATURESIZE auto
                PARTIALS FALSE
                POSITION cc
            END
        END
        METADATA
            # drill-down identify service record.
                  'identify_record'    'templates/identify.html'
            # query.php / "Search Parcels" functionality.
            'itemquery'    'templates/search_result.html'
            'itemquery-filter'    '/.*[qstring].*/i'
            'qstring_validation_pattern' '.'
            # Feature reports are stored in the conf/feature_report
directory.
            'feature_report' 'parcel.xml'
                  'select_record'    'templates/select_result.html'
            'select_header' 'templates/select_header.html'
            'popups' 'parcels_popup.html'
        END
        TOLERANCE 0
        END
END ## end Map
- നെടുമ്പാല ജയ്സെന്‍ -
«´¨`·* .  Jaisen . *..´¨`»
      ( `v´ )
        `v´
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130509/45b51b93/attachment.html>
More information about the Geomoose-users mailing list
