[Geomoose-users] Help; is there anybody that knows how to use a DFX or KML in Geomoose?
Brent Fraser bfraser at geoanalytic.com
Thu Nov 14 17:02:27 PST 2013
Your map file needs the
     CONNECTIONTYPE OGR
     CONNECTION 'T:\GeoData\Parcels\Alberta\brooks.dxf' # entities'
part instead of your DATA statment.  So it should look like:
     CONNECTIONTYPE OGR
     CONNECTION 'cci.dxf' # entities'
instead of
         DATA './cci.dxf'
Mapserver does not understand DXF; it needs to use the OGR library to
read it.
What is the coordinate system of your DXF file?
Best Regards,
Brent Fraser
On 11/14/2013 5:19 PM, Behr Mirfathali wrote:
> Forgive me, but I do not know how a header works or where it needs to go.
> This is my .map file. Should this work? It is pretty much a direct
> knock off from the Geomoose Demo 'Parcels'.
> MAP
> NAME 'cci'
> SIZE 800 650
> STATUS ON
> EXTENT  427632.500000 4893613.330000 560300.922104 5015936.680000
> UNITS METERS
> INCLUDE "../../geomoose_globals.map"
> WEB
> METADATA
> 'ows_title' 'CCI Maps'
> 'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:3857'
> 'ows_enable_request' '*'
> 'ows_onlineresource' 'http://www.geomoose.org'
> END
> END
> PROJECTION
> 'init=epsg:3875'
> END
> LEGEND
>       STATUS ON
>       LABEL
> TYPE TRUETYPE
> FONT vera_sans
> SIZE 8
> COLOR 0 0 0
>       END
> END
> LAYER
> NAME cci
> DATA './cci.dxf'
> STATUS ON
> TYPE Line
> LABELCACHE ON
> LABELMAXSCALE 20000
> CLASS
> NAME 'cci'
> STYLE
> WIDTH 3
> COLOR -1 -1 -1
> OUTLINECOLOR 93 181 53
> MAXSCALEDENOM 15000
> END
>     STYLEITEM 'AUTO'
>     CLASS
>        NAME 'Rural DXF'
>     END
> END
> LABEL
> TYPE TRUETYPE
> FONT vera_sans
> SIZE 8
> ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 254 254 200
>                                                 BUFFER 4
> MINFEATURESIZE auto
> PARTIALS FALSE
> POSITION cc
> END
> END
> METADATA
> # drill-down identify service record.
> 'identify_record'              'templates/identify.html'
> # query.php / "Search Parcels" functionality.
> 'itemquery'         'templates/search_result.html'
> 'itemquery-filter'             '/.*[qstring].*/i'
> 'qstring_validation_pattern' '.'
> # Feature reports are stored in the conf/feature_report directory.
> 'feature_report' 'parcel.xml'
>                                 'select_record'
> 'templates/select_result.html'
> 'select_header' 'templates/select_header.html'
> 'popups' 'parcels_popup.html'
> END
> TOLERANCE 0
>   END
> END ## end Map
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Thursday, November 14, 2013 3:53 PM
> *To:* Behr Mirfathali
> *Subject:* Re: [Geomoose-users] Help; is there anybody that knows how
> They are produced by a gov't agency. Here's the header part
> $ACADVER
>   1
> AC1009
>   9
> Best Regards,
> Brent Fraser
> On 11/14/2013 3:49 PM, Behr Mirfathali wrote:
>     Thank you
>     I am glad to know it works.
>     BTW, what AutoCAD version of DFX file have you been saving to?
>     *Sent:* Thursday, November 14, 2013 2:44 PM
>     *To:* Behr Mirfathali; geomoose-users at lists.osgeo.org
>     <mailto:geomoose-users at lists.osgeo.org>
>     Behr,
>       I've used DXF with GeoMoose.    Likely your version of Mapserver
>     has the capabilities built in.  Try something like I did by
>     setting up a mapserver mapsource with a map file containing a
>     layer definition like:
>       LAYER
>         NAME 'Alberta'
>         STATUS on
>         TYPE LINE
>         CONNECTIONTYPE OGR
>         PROJECTION
>             'init=epsg:3403'
>         END
>         STYLEITEM 'AUTO'
>         CLASS
>            NAME 'Rural DXF'
>         END
>       END
>     Typical problems relate to the coordinates stored in the DXF files
>     (sometimes "local" coordinate systems are used).
>     Best Regards,
>     Brent Fraser
>     On 11/14/2013 2:58 PM, Behr Mirfathali wrote:
>         Hello,
>         I have files I am exporting out of AutoCAD Map for Geomoose.
>         We have so many text layers to deal with so it looks like a
>         DWF or a KML/KMZ layer would be easier to work with. I did a
>         little research and I found that both types can be used.
>         http://gdal.org/ogr/ogr_formats.html  For KML it says it needs
>         *(read support needs libexpat). *I am not sure what is meant
>         by 'read support'.
>         And
>         According to this
>         http://wiki.ieee-earth.org/Documents/GEOSS_Tutorials/GEOSS_Provider_Tutorials/Web_Feature_Service_Tutorial_for_GEOSS_Providers/Section_4%3A_Provisioning%2F%2FUsing_the_service_or_application/Section_4.3%3A_Detail_Steps_for_Use_Cases/Section_4.3.1%3A_Offering_a_DXF_file_with_mapserver_WFS
>         I would have to install OSGeo4W to the server. But what
>         version? Also, what version of DXF? 2013? 2010? I would have
>         thought the original Mapserver would have at least been able
>         to use the DXF format given its history.
>         Any thoughts?
>         All help is appreciated.
>         Thank you
>         Behr
>         *Behr Mirfathali* | Engineering Technician
>         Direct 360.326.5582 | Fax 541.265.8946|
>         behr at coastcom.net <mailto:behr at coastcom.net> |
>         www.coastcom.net <http://www.coastcom.net/>
>         signature
>         _______________________________________________
>         Geomoose-users mailing list
>         Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131114/b4207c67/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131114/b4207c67/attachment-0001.jpe>
More information about the Geomoose-users mailing list
