[Geomoose-users] Identify Tolerance
Anderson, Dean anderson.dean at co.polk.or.us
Fri Aug 29 15:15:49 PDT 2014
Here is what I use to identify roads and the tolerances seems to work fine.
 (TOLERANCE 100
  TOLERANCEUNITS FEET)  as follows:
Layer  #14
  Name "Roads"
  Data './data/RoadAllWeb'
  Status On
  Type Line
  METADATA
  'identify_record' 'templates/identify_road.html'
  END
  TOLERANCE 100
  TOLERANCEUNITS FEET
  ClassItem "RoadType"
Class
   Name "Major Roads"
   minscale 40001
   maxscale 100000
   EXPRESSION "Major Roads"
STYLE
Width 4
COLOR 168 112 0
END
STYLE
width 2
COLOR 255 211 127
END
  End
  Class
   Name "Major Roads"
   maxscale 40000
   Minscale 10001
STYLE
width 4
COLOR 168 112 0
END
STYLE
width 2
COLOR 255 211 127
END
  End
  Class
   Name "Major Roads"
   maxscale 10000
STYLE
width 6
COLOR 168 112 0
END
STYLE
width 3
COLOR 255 211 127
END
  End
  Class
   Name "Standard Roads"
   EXPRESSION "Local Roads"
   minscale 40001
   maxscale 100000
STYLE
width 2
COLOR 160 160 160
END
STYLE
width 1
COLOR 204 204 204
END
  End
  Class
   maxscale 40000
   minscale 10001
STYLE
width 4
COLOR 160 160 160
END
STYLE
width 2
COLOR 204 204 204
END
  End
  Class
   maxscale 10000
STYLE
width 6
COLOR 160 160 160
END
STYLE
width 3
COLOR 204 204 204
END
  End
End
On Fri, Aug 29, 2014 at 1:44 PM, Clinton Olsen <clintono at emery.utah.gov>
wrote:
> When I try to identify a line or a point I get coordinates on the left
> side of the template.  Is there a way to troubleshoot the identify tool?  I
> know I might not have the tolerance set right but how can I figure out what
> the tolerance should be.  I have tolerance numbers I have used range from 0
> - 100.  I have tried meters, feet, pixels.  I referenced the how to setup
> identify on the geomoose.org site and I got one of my polygon layers to
> work.  My template and mapfile are listed below.  How can I troubleshoot
> what is wrong with these files?
> <!-- MapServer Template -->
> <tr><td colspan="2"><b>Boulder Areas</b></td></tr>
> <tr><td>Boulder Area: [SECTION]</td></tr>
> <tr><td>Boulder: [BOULDER]</td></tr>
> <tr><td>LAT: [LAT]</td></tr>
> <tr><td>LONG: [LONG]</td></tr>
> <tr><hr></td></tr>
> MAP
> NAME 'BOULDERS'
> SIZE 800 650
>  STATUS ON
> EXTENT  -12381838.298411 4760938.642311 -12327375.283263 4806362.074758
> UNITS METERS
>  INCLUDE "../../geomoose_globals.map"
> WEB
> METADATA
>  'ows_title' 'Boulders'
> 'ows_srs' 'EPSG:3857'
> 'ows_enable_request' '*'
>  'ows_onlineresource' 'http://www.geomoose.org'
> END
>  END
> PROJECTION
> 'init=EPSG:3857'
>  END
> LEGEND
>       STATUS ON
>       LABEL
>  TYPE TRUETYPE
> FONT vera_sans
> SIZE 8
> COLOR 0 0 0
>       END
> END
> LAYER
>         NAME "boulders"
>         DATA "boulders.shp"
>         STATUS DEFAULT
>         TYPE POINT
>         TOLERANCE 0
>         TOLERANCEUNITS meters
>           LABELITEM 'BOULDER'
>         LABELCACHE ON
>         LABELMAXSCALE 100000
>             CLASS
>               NAME 'Boulders'
>            STYLE
>                SYMBOL 'CIRCLE'
>  COLOR 255 102 51
> OUTLINECOLOR 0 0 0
>              SIZE 8
>                   END
>   LABEL
>          TYPE TRUETYPE
>          FONT vera_sans-bold
>          SIZE 8
>          ANTIALIAS TRUE
>          COLOR 0 0 0
>          OUTLINECOLOR 254 254 254
>          BUFFER 4
>          PARTIALS FALSE
>          POSITION auto
>  SIZE 7
>          END
>         END
> METADATA
> # drill-down identify service record.
>        'identify_record' 'identify_boulders.html'
>  END
> TOLERANCE 0
> END
> END
> Clinton Olsen
> IS/GIS Technician
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
Dean R Anderson
IT Director
Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140829/ff7146d6/attachment-0001.html>
More information about the Geomoose-users mailing list
