[Geomoose-users] TinyOWS question.
Dan Little
theduckylittle at gmail.com
Wed Oct 8 06:26:08 PDT 2014
Bobb,
In infamous programmer parlance, I have TinyOWS working locally. The
following has worked for me recently:
- Deleting features
- Updating feature attributes
I did just get a core dump when I tried to insert a feature but I'm
not sure as to what the root cause of the core dump was. I also am
running a pretty old (and probably straight-from-SVN) version of
TinyOWS.
If you want to file a 2.8 issue on GitHub for better TinyOWS docs I'll
definitely make sure it's on the queue.
On Wed, Sep 3, 2014 at 5:28 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Bobb,
> It has been some time since I tried to integrate GeoMoose v2.6 editing with
> TinyOWS (2.5 years? really?). The two main problems I ran into were:
> 1. No inserts allowed by TinyOWS, only edit and delete (a bug; I'll look up
> the version. hopefully fixed by now)
> 2. No display in one projection and store in another (a GeoMoose fix
> required, I think)
> and of course difficulty setting up the config files because of
> terminology/name-space mapping between:
> - PostGIS (btw, only PostGIS supported by TinyOWS still?) ,
> - TinyOWS XML
> - OpenLayers API
> - GeoMoose Mapbook
> I've attached the doc I had made (basically an edit of Dan's GeoServer doc),
> but no guarantee they are still valid (or ever were).
> Best Regards,
> Brent Fraser
> On 9/3/2014 11:46 AM, Basques, Bob (CI-StPaul) wrote:
> All (and I’m told, specifically Brent . . .)
> We need a working example of a Mapfile for connecting to TinyOWS for editing
> from GeoMOOSE.
> TinyOWS is throwing Schema errors on edit.
> Thanks
> Bobb
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
