[Geomoose-users] USGS NationalMap WMS Error
TC Haddad
tchaddad at gmail.com
Wed Oct 22 11:45:47 PDT 2014
Ummm... this is just a long shot, but it looks like by default, this is a
WMS 1.3.0, not WMS 1.1.1
In WMS 1.3.0, you have to use CRS=EPSG:3857 instead of SRS=EPSG:3857 in the
URL.
It does look like the service also supports WMS 1.1.1, so I would try
adding the version to your URL fragment, to force the version you want to
use, and see if it makes the server happy with using SRS=EPSG:3857
like so:
http://basemap.
<http://basemap.nationalmap.gov/ArcGIS/services/USGSImageryOnly/MapServer/WMSServer?version=1.1.1&>
Mapserver should take care of the rest of the differences between 1.3.0 and
1.1.1.
Tanya
On Wed, Oct 22, 2014 at 11:08 AM, Jim Klassen <klassen.js at gmail.com> wrote:
> I am having difficulty connecting GeoMoose to the NationalMap's imagery
> service.
> The GetMap response says invalid SRS. It appears GeoMoose is sending
> SRS=EPSG%3A3857 and the service is expecting SRS=EPSG:3857. This used
> to work a while ago. I am not sure what changed. I've tried with
> GeoMoose 2.6.1 through master.
> Any thoughts what I might be doing wrong?
> Mapbook fragment:
> <map-source name='tnm_usgsimagery' type="wms" tiled="false"
> opacity="1.0">
> <param name="TRANSPARENT" value="false"/>
> <param name="FORMAT" value="image/jpeg"/>
> <url>
> ?</url>
> <layer name="0"/>
> </map-source>
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20141022/5ebf3061/attachment.html>
More information about the Geomoose-users
