[Geomoose-users] Identify Tolerance
Brent Fraser bfraser at geoanalytic.com
Fri Sep 5 15:29:49 PDT 2014
Clinton,
   Don't forget to "Enable network traffic capturing" by clicking the
">" button so it turns into a red square:
then try the Identify in your browser...
Best Regards,
Brent Fraser
On 9/5/2014 2:33 PM, Clinton Olsen wrote:
> Brent,
> When I try to identify my point layer and check on the Response Body
> under the F12 network tab.  My the page is blank with no data to view.
> I also have two polygon layers that have the identify feature working
> correctly.  And when I checked their Response Body after identifying
> it is blank and says no data to view.
> The geomoose demo on the link you sent to me give a response back from
> the server, but mine are not giving responses even though some of the
> layers still post back identify results.
> I changed my tolerance to 50 and got the same result.  I tried
> tolerance 500 and got the same result.  I double checked the other
> suggestions from TC Haddad, and still no change.
> On Fri, Sep 5, 2014 at 11:18 AM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
>     Clinton,
>     if you double click on the "/geomoose2/php/idenitfy.php" entry in
>     the Internet Explorer debugger, then click on the "Response Body"
>     tab, it should show you what was sent from the server.  It should
>     look something like (I'm using the Geomoose demo at
>     http://demo.geomoose.org/master/):
>     <results>
>     <script> GeoMOOSE.clearLayerParameters('highlight');
>     GeoMOOSE.turnLayerOff('highlight/highlight');</script>
>     <html><![CDATA[<!-- MapServer Template -->
>     Detailed information for the area you clicked on the map...
>     <table border="0">
>     <tr>
>     <td colspan="2"><b><u>Ground Coordinates</u></b>
>     <br>
>     <b>X: </b>486432.0118221
>     <br>
>     <b>Y: </b>4939167.527998</td>
>     </tr>
>     <tr>
>     <td> </td>
>     <td> </td>
>     </tr>
>     </table>
>     <table border="0" cellpadding="1" cellspacing="2">
>     <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
>     <tr>
>     <td align="right"><b>PIN:</b></td>
>     <td>037- <a
>     href="javascript:GeoMOOSE.startService('feature_report', {'PIN' :
>     '037-', 'src' : 'parcels/parcels'})">Report</a></td>
>     </tr>
>     <tr>
>     <td align="right"><b>Owner Name:</b></td>
>     <td>Andera Harris</td>
>     </tr>
>     <tr>
>     <td align="right"><b>Est. Market Value:</b></td>
>     <td>0</td>
>     </tr>
>     <tr>
>     <td align="right"><b>Acres:</b></td>
>     <td>159.90</td>
>     </tr>
>     <tr>
>     <td> </td>
>     <td> </td>
>     </tr>
>     ]]></html><footer><![CDATA[<b>Disclaimer: This information is
>     being distributed as demonstation data only.  You should not use
>     the data for any other purposes.</b>
>     ]]></footer>
>     </results>
>     Best Regards,
>     Brent Fraser
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140905/85358038/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140905/85358038/attachment-0001.png>
More information about the Geomoose-users mailing list
