[Geomoose-users] refresh layer
Jim Klassen klassen.js at gmail.com
Thu Apr 30 09:13:42 PDT 2015
I hadn't noticed flicker, but I wasn't looking either.  There is
certainty a lot room for improvement to this code.  One of the changes I
had in the newer/very single purpose version that should get backported
is I create the layer in the mapbook and then set the layer id as a
config option.  This lets the user control the styles and turn it on/off
normally.
I would have released it a few years ago if it was more polished or I
thought there was interest.
On 04/29/2015 04:58 PM, Brent Fraser wrote:
> Jim,
>   Thanks!  Looks similar to what I was thinking, but I was planning to
> just change the coordinates of markers if the "fid" matched to
> eliminate "flicker" as the markers were removed and then added.  Did
> you see any flicker in your implementation?
> Thanks again.
> Best Regards,
> Brent Fraser
> On 4/29/2015 2:52 PM, Jim Klassen wrote:
>> I've been playing around with something like this on and off.
>> I haven't tested this code recently, but here is an example of an
>> extension that creates a vector layer and keeps it updated based on a
>> GeoJSON feed from the web server.  I have a newer version, but it is
>> very specific to one project and would need some effort to make it more
>> general.
>> https://github.com/klassenjs/geomoose-js/blob/live-data-extension/extensions/LiveData.js
>> On 04/26/2015 10:04 AM, Brent Fraser wrote:
>>> Hello GeoMoosers,
>>> I might be interested in a GeoMoose Refresh Layer as well.
>>> I've been doing a little experimenting with phone tracking app:
>>>      https://www.websmithing.com/gps-tracker/
>>> , a tracking system composed of:
>>>      - a smart phone ( android,windows,ios,etc) position (and other
>>> values) reporting app
>>>      - a little server-side PHP code for receiving (and reporting) the
>>> positions
>>>      - a database (currently SQL Server or MySQL, with Postgres and
>>> SQLite to come) to store the data
>>>      - some Leaflet-based Javascript for display
>>> And while I could render an image of the positions directly from the
>>> database using mapserver (and ogr), I was thinking that a geojson (or
>>> WFS-T?) feed might be a better solution.  It might lead to something
>>> like:
>>> https://www.mapbox.com/mapbox.js/example/v1.0.0/rotating-controlling-marker/
>>> within GeoMoose.
>>> Thoughts?
>>> Best Regards,
>>> Brent Fraser
>>> On 2/5/2015 8:37 AM, Dan Little wrote:
>>>> That is *exactly* what Bobb and Jim are working on, maybe they can
>>>> share a little bit of code?
>>>> On Mon, Jan 12, 2015 at 4:55 AM, Richard Camejo <rfcamejo at gmail.com>
>>>> wrote:
>>>>> Dan,
>>>>> in particular we are using GeoMOOSE to display a GIS for the port of
>>>>> Montevideo, Uruguay.
>>>>> One of the layers shown is the movement of ships in the harbor
>>>>> area, it
>>>>> would be nice to automatically refresh the layer of boats to see the
>>>>> movement of ships.
>>>>> Thank You.
>>>>> 2015-01-11 15:00 GMT-02:00 Dan Little <theduckylittle at gmail.com>:
>>>>>> Richard,
>>>>>> We just dropped the tool from the UI a while ago. Feedback form many
>>>>>> users is that it was confusing and mostly unnecessary. It was mostly
>>>>>> designed for doing debugging  demo layers when we were doing
>>>>>> development.
>>>>>> What's your specific problem? I know Bobb and JimK have layers
>>>>>> that do
>>>>>> tracking and they've written extensions to do automatically
>>>>>> refreshing
>>>>>> layers.
>>>>>> Thanks!
>>>>>> On Sat, Jan 10, 2015 at 8:56 AM, Richard Camejo <rfcamejo at gmail.com>
>>>>>> wrote:
>>>>>>> Hi, I have seen that the possibility of refresh GeoMOOSE layer is
>>>>>>> deprecated
>>>>>>> in 2.6.1.
>>>>>>> Anybody know any alternatives, or there is the possibility of
>>>>>>> automatically
>>>>>>> refreshing layer in 2.6.1
>>>>>>> Thanks, greetings ...
>>>>>>> Richard.
>>>>>>> _______________________________________________
>>>>>>> Geomoose-users mailing list
>>>>>>> Geomoose-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
