[Geomoose-users] Problem in query.php if layer SRS different from map SRS
Brent Fraser bfraser at geoanalytic.com
Tue Dec 22 08:09:50 PST 2015
Dan,
   I'm not sure I need to file a ticket, based on my table below from
the previous email.
   I deal with data from all of the the world, so I like to keep the
data in a common coordinate system (epsg:4326, AKA lat/Lon WGS84). And I
like using Geomoose configured to display the data in Web Mercator.  So
my new rule is to set up my map files to be:
MAP
     PROJECTION
         "+init=epsg:4326"
     END # of PROJECTION
     LAYER
         :  # no need for a projection object here
     END # Layer
END # Map
   I used to set my MAP Projection to the output projection (old-school
mapserver), but since Geomoose uses WMS protocol to request a rendered
image from mapserver, it passes the desired projection (Web Mercator)
and it is all good.
i just need to make sure I edit my search template to be (note the
"precision=5" and "EPSG:4326"):
<!-- MapServer Template -->
<b>PLOT NO:</b> <a data-pin="[PLOTNO_1]" id="gm-parcel-[PLOTNO_1]"
class='sprite-control sprite-control-find-selected' style="padding-left:
22px" parcel-shape="[shpxy *precision=5*]"
href="javascript:GeoMOOSE.zoomToPointsList(dojo.byId('gm-parcel-[PLOTNO_1]').getAttribute('parcel-shape'),
'*EPSG:4326*');">[PLOTNO_1]</a><br/>
<b>PLOT_NO2:</b> [PLOTNO_1]<br/>
<hr/>
so the zoom-to link works.
Best Regards,
Brent Fraser
On 12/21/2015 10:12 AM, Dan Little wrote:
> Can someone formalize this into a ticket for me? Brent? Tanya?
> I'd like to make sure I've got automated tests for this.  If I need to
> pull in some OSM data to make a test then I will but if someone can
> summarize this for me in a quick-and-tangible form I'll make it
> happen.
> On Mon, Jul 27, 2015 at 7:12 PM, TC Haddad <tchaddad at gmail.com> wrote:
>> Wow thanks Brent.
>> I would say we're at the point where this can be filed as a GitHub issue-
>> why don't you open one, and link to this thread using:
>> http://lists.osgeo.org/pipermail/geomoose-users/2015-July/005735.html
>> so that we have an easy way to get to your findings.
>> On Mon, Jul 27, 2015 at 5:02 PM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>> So I did some tests on the Geomoose services (both v2.7.1 and 2.8.0) using
>>> different Spatial Reference Systems (SRS) .
>>> The Short story:
>>>          You can have the Geomoose mapping website in one SRS and the data
>>> in another (even lat/lon) as long as the SRS of the MAP object in the map
>>> file and the LAYER(s) in the map file are the same.  For example Geomoose
>>> website in Web Mercator, MAP object in UTM and LAYER in UTM.  Another
>>> example is Geomoose website in Web Mercator, MAP object in Lat/Lon (e.g.
>>> EPSG:4326) and LAYER in Lat/Lon.  Both of these configurations will work
>>> with the stock Geomoose services.
>>> The Long story:
>>>    A few of the PHP files make the assumption that the MAP object and the
>>> LAYER object(s) in the map file have the same SRS.  Here's a table showing
>>> the results of my tests.  All of the tests use Web Mercator as the display
>>> SRS in Geomoose.  UTM/UTM means that the MAP object SRS is UTM as is the
>>> LAYER SRS.   UTM/Geo means the MAP object is UTM but the LAYER SRS is
>>> Lat/lon (AKA Geographic,EPSG4326).  Geo/Geo means both the MAP object and
>>> LAYER objects SRS are Lat/lon.  So you can see that as long as the MAP and
>>> LAYER SRS are the same, the Geomoose service functions will work.
>>>                              v2.7.1                 v2.8.0
>>> Map/Layer SRS:    UTM/UTM UTM/Geo Geo/Geo  UTM/UTM UTM/Geo Geo/Geo
>>> Function:
>>> Rendering            yes    yes    yes        yes    yes    yes
>>> Printing             yes    yes    yes        yes    yes    yes
>>> Identify             yes    yes    yes        yes    yes    yes
>>>   Feature Report      yes    no(1)  yes        yes    no(1)  yes
>>> Popups               yes    yes    yes        yes    yes    yes
>>> Select Features      yes    no(2)  yes        yes    no(2)  yes
>>>   highlight           yes    -      yes        yes    -      yes
>>>   PDF Mailing Labels  yes    -      yes        yes    -      yes
>>>   HTML Mailing Labels yes    -      yes        yes    -      yes
>>>   CSV Mailing Labels  yes    -      yes        yes    -      yes
>>> Search Parcels       yes    no(3)  yes        yes    no(3)  yes
>>>   Zoom-to link        yes    -      no(4)      yes    -      no(4)
>>> (1) map portion empty, but parcel attributes displayed
>>>    The "bug":feature_report.php assumes the map and layer portions of the
>>> map file use the same SRS and so set the map object's extent to the shape
>>> bounds without re-projecting it.
>>> (2) Found Shapes: 0
>>>    The "bug":select.php assumes the map and layer portions of the map file
>>> use the same SRS
>>> (3) No results found for your query!
>>>    The "bug":query.php assumes the map and layer portions of the map file
>>> use the same SRS so do not re-project the results of "$ext =
>>> $queryLayer->getExtent();" which returns the extent of the shapefile in the
>>> layer's SRS.
>>> (4) Zooms to the wrong location
>>>    The "bug": the search_result.html template needs to be changed to return
>>> coordinates with decimal precision:
>>> parcel-shape="[shpxy precision=5]"
>>> and of course the SRS of the coordinates must be changed to:
>>> 'EPSG:4326'
>>> Best Regards,
>>> Brent Fraser
>>> On 7/27/2015 1:38 PM, Brent Fraser wrote:
>>>    That may be true, but it lets too many bugs/limitations through testing.
>>> And if the functions work for Geographic coordinate data, they will likely
>>> work for projected data sets.
>>>    I think I'll try converting the parcels to geographic coordinates and
>>> see how many functions still work...
>>> Best Regards,
>>> Brent Fraser
>>> On 7/27/2015 12:29 PM, James Klassen wrote:
>>> 26915 (or county coordinates) would be more appropriate for the parcel
>>> data.  First it is what it was and second parcels are one of the most likely
>>> layers to be in a local projection.
>>> On Jul 27, 2015 12:38 PM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
>>>> Bobb,
>>>>    Yes! Change the parcel data to EPSG:4326 and test the rendering,
>>>> Identify, Select Features, Search Parcels, Printing,  and Feature Report
>>>> functions (that would likely decrease my support workload by 80%).
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 7/27/2015 8:17 AM, Basques, Bob (CI-StPaul) wrote:
>>>> All,
>>>> I wonder if it wouldn’t be prudent to include data from more than one
>>>> projection in order to insure that all reprojection conversions are working.
>>>> bobb
>>>> On Jul 26, 2015, at 12:37 PM, TC Haddad <tchaddad at gmail.com> wrote:
>>>> Just as an overall comment, there are 2 very distinct user groups for the
>>>> demo - people who only care about Web Mercator stuff working, and people who
>>>> are trying to work in a local projection.
>>>> What we have in the demo is working pretty well for the first group, and
>>>> it is a bit unfriendly to beginners in the second group, as projections show
>>>> up in multiple places where beginners are likely to run into trouble (e.g.
>>>> even setting up your zoom levels in the Mapbook.xml). It's compounded if a
>>>> user runs into a bug, and doesn't know it's a bug.
>>>> Probably worth a review of the docs to see how we might improve in this
>>>> area...
>>>> Tanya
>>>> On Sun, Jul 26, 2015 at 10:12 AM, Brent Fraser <bfraser at geoanalytic.com>
>>>> wrote:
>>>>> Tanya,
>>>>>    Just by looking at the code in Github I see that there is still no
>>>>> re-projection of the extent before the query call, so i expect that is is
>>>>> still broken (but I will try v2.8).  Now that I'm getting results back I ran
>>>>> into the "zoom to results" bug you've referenced, so that saved me some
>>>>> time.  Thanks!
>>>>> Personally, I think the parcel data in our demo should be in EPSG:4326
>>>>> so we can discover these problems in our testing before release.
>>>>> Best Regards,
>>>>> Brent Fraser
>>>>> On 7/26/2015 10:57 AM, TC Haddad wrote:
>>>>> There was a bug that was fixed recently that may relate:
>>>>> https://github.com/geomoose/geomoose/issues/90
>>>>> You could try grabbing the relevant changes to query.php:
>>>>> https://github.com/geomoose/geomoose-services/commit/dacfa7e2648c5bcd3ec38308cb1199621a07c390
>>>>> Or you could try a 2.8 install to see if the same problem is present
>>>>> (before filing a new issue...).
>>>>> On Sun, Jul 26, 2015 at 9:32 AM, Brent Fraser <bfraser at geoanalytic.com>
>>>>> wrote:
>>>>>> Hi Developers (and others),
>>>>>>    While debugging a user's problem with using his data with query.php,
>>>>>> I see that line 376 in github (or line 420-ish in GM 2.7.1):
>>>>>>      $ext = $queryLayer->getExtent();
>>>>>> then the layer's extent is used for the query a little later:
>>>>>>      $queryLayer->queryByRect($ext);
>>>>>> This fails to find any features since in my case the coordinate systems
>>>>>> of the map and layer are different, and the queryByrect must be done using a
>>>>>> rectangle in the MAP's SRS not the LAYER's SRS.  I did a little hack to
>>>>>> re-project the extent just before the queryByRect:
>>>>>>                      // re-project the layer's extent into the map SRS
>>>>>> for querying:
>>>>>>                      $map_projection_def = $map->getProjection();
>>>>>>                      $map_projection_obj =
>>>>>> ms_newProjectionObj($map_projection_def);
>>>>>>                      if($queryLayer->getProjection() != NULL) {
>>>>>>                          $projection = $queryLayer->getProjection();
>>>>>>                      if($projection != NULL) {
>>>>>>                          # reproject the query shape as available.
>>>>>>                          $projection = ms_newProjectionObj($projection);
>>>>>>                      if($projection) {
>>>>>>                          $ext->project($projection,
>>>>>> $map_projection_obj);
>>>>>>                      if($DEBUG) {
>>>>>>                          error_log(implode(',',
>>>>>> array($ext->minx,$ext->miny,$ext->maxx,$ext->maxy)));
>>>>>>                          error_log("<br/>extent for query in map
>>>>>> SRS.<br/>");
>>>>>> I thought I would get comments before filing an Issue.
>>>>>> So any comments?
>>>>>> Best Regards,
>>>>>> Brent Fraser
>>>>>> _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20151222/3e8722a8/attachment-0001.html>
More information about the Geomoose-users mailing list
