[Geomoose-users] Reset Catalog Option
lfilak at medinaco.org lfilak at medinaco.org
Thu Feb 5 11:14:41 PST 2015
Mark,
I like the ingenuity and may try it.
However, because the logic is working in reverse I filed enhancement #68 in
GitHub so nobody is confused by the logic when I hand the project off.
Thanks.
Lowell
Mark Volz writes:
> Lowell,
> Perhaps the basemap buttons extension could do the trick.  Normally when
> the basemap button is pressed all of the basemaps are turned off, then
> selected layers are turned back on.  Maybe it might be as easy as saying
> that every layer is a basemap, and then when you press the Main layers
> button you could turn on your default layers.
> CONFIGURATION['BasemapButtonsExtension'] = {
> 	'baseLayers': 'map/layer1,map/layer2,........',
> 	'autoBaseLayers': false,
> 	'buttons': [
> 			'label':'Main Background',
> 			'title':'Main Background',
> 			'layers': [
> 				'MapCache/StandardBackground,defaultmap/layer1,defaultmap/layer2'
> 			'checked': true
> I don't know if this will work but it might be worth a shot?
> Sincerely,
> Mark Volz
>> -----Original Message-----
>> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-
>> bounces at lists.osgeo.org] On Behalf Of lfilak at medinaco.org
>> Sent: Thursday, February 05, 2015 11:35 AM
>> To: Dan Little
>> Cc: lfilak at medinaco.org; GeoMOOSE Users List
>> Subject: Re: [Geomoose-users] Reset Catalog Option
>> Thanks.
>> Hmmm...
>> Is there anything existing for maintaining Previous Extent after a reload?
>> Dan Little writes:
>> > There's nothing built-in to do that but it would be a reasonable
>> > custom tool to write.
>> > Alternatively, you can hit "Reload" in the browser but that, of
>> > course, resets your zoom too.
>> > On Wed, Jan 28, 2015 at 3:48 PM,  <lfilak at medinaco.org> wrote:
>> >> We are fairly new to GeoMOOSE but feel it is a great project and easy
>> >> to customize. Thank you!
>> >> One question has come up as we add more and more layers to the catalog:
>> >> Is there a setting or tool which will allow the user to "reset" the
>> >> layers in the catalog to the initial on/off values?
>> >> Thank you.
>> Hmmm...
Lowell Filak
Medina County Engineers
330.723.9561
http://webcal.medinaco.org/cgi-bin/webcal.cgi?cal=LFilak+in+out
More information about the Geomoose-users mailing list
