[Geomoose-users] print osm tiles
Dante Fuster dante.fuster at gmail.com
Sat Feb 14 10:59:12 PST 2015
HI
sorry
Globalgis.php is only for connect to postgis,  is not necessary.
an example using direct printing print2_ant.php is in
190.102.141.131/midis
with print icon
Greetings
Dante Fuster
2015-02-13 4:12 GMT-05:00 <geo.graefin at web.de>:
> Dear Dante Fuster,
> thank you very much for your help!
> What is the "globalgis.php" in your php file?
> Should I not also provide the new service as a print service in the
> toolbar?
> <tool name="print" title="Karte drucken" type="service" service="print2"
> selectable="false" icon-class="sprite-control sprite-control-printer"/>
> Should I note something else? Because it does not work at the moment.
> Thank you in advance for anwering!
> Greetings, Geograefin
> *Gesendet:* Donnerstag, 12. Februar 2015 um 20:59 Uhr
> *Von:* "Dante Fuster" <dante.fuster at gmail.com>
> *An:* "Brent Fraser" <bfraser at geoanalytic.com>
> *Cc:* geo.graefin at web.de, geomoose-users at lists.osgeo.org
> *Betreff:* Re: [Geomoose-users] print osm tiles
>    Hello
> I had also  the same problem to print a map with background like
> googlemaps or OSM,  i dont need  complex print and i resolved to generate a
> screen with only the content of the map and sending to save (screen
> capture) to JPG or print directly.
> i create a new service:
>      <service name="print2" display="false">
>         <url>php/print2.php</url>
>         <step type='input'>
>                 <input type="hidden" name="impresion" value="true"/>
>         </step>
>     </service>
> and the print2.php
> <?php
> include('config.php');
> include('globalgis.php');
> # Turn off the warning reporting
> error_reporting(E_ERROR | E_PARSE);
> //$predicates = array();
> # the mode!
>     header('Content-type: text/xml');
>     <results>
>     <script><![CDATA[
>     var barra =
> document.getElementById("OpenLayers.Control.PanZoomBar_11");
>   barra.style.display="none";
>   var ficha = document.getElementById("map");
>   params  = 'width='+screen.width;
>   params += ', height='+screen.height;
>   params += ', scrollbars=auto';
>   var ventimp = window.open(' ', 'popimpr',params);
>   ventimp.document.write("<html>");
>   ventimp.document.write("<head>");
>   ventimp.document.write("<script type='text/javascript' src='
> http://ajax.googleapis.com/ajax/libs/jquery/1.10.2/jquery.js
> '></script>");
> src='build/jquery.fullscreen-min.js'></script>");
>   ventimp.document.write("</head>");
>   ventimp.document.write("<body>");
>   ventimp.document.write( ficha.innerHTML );
>   ventimp.document.write("</body>");
>     ventimp.document.write("<div id='buttons'>");
>   ventimp.document.write("    <button
> onclick='$(document).fullScreen(true)' autofocus='autofocus'>F</button>");
>   ventimp.document.write("  </div>");
>   ventimp.document.close();
> //ventimp.print( );
> //  ventimp.close();
>    barra.style.display="";
>    GeoMOOSE.changeTab('catalog');
>     ]]></script>
>     <html><![CDATA[
>     </html>
>     </results>
> or a variation  to print directly
> <?php
> # the mode!
>     <results>
>     <script><![CDATA[
>           var barra =
>   var ventimp = window.open(' ', 'popimpr');
> ventimp.print( );
>   ventimp.close();
>     ]]></script>
>     <html><![CDATA[
>     </html>
>     </results>
> i hope to help you , is simple and  was the minimum that i needed
> Regards
> Dante Fuster
> 2015-02-10 11:20 GMT-05:00 Brent Fraser <bfraser at geoanalytic.com>:
>>  Geograefin,
>>   I just copied the "frmt_wms_openstreetmap_tms.xml" file into the same
>> folder as the map file and it works fine..  I suspect you could put the
>> full path to the xml file in the DATA object in the map file, but I have
>> not tried it.
>>   Interestingly, the xml file (along with many others) are delivered with
>> the GDAL source code, but not with the binary distributions I use.  The
>> files are:
>> frmt_wms_metacarta_tms.xml
>> frmt_wms_metacarta_wmsc.xml
>> frmt_wms_onearth_global_mosaic.xml
>> frmt_wms_tileservice_bmng.xml
>> frmt_wms_tileservice_nysdop2004.xml
>> I may have to try some of these!
>> Best Regards,
>> Brent Fraser
>>  On 2/10/2015 8:42 AM, geo.graefin at web.de wrote:
>> Hello Brent,
>> I'm sorry to bother you again, but I could not find where to store the
>> xml file. How does the MapServer interact with GDAL? Where I have to
>> reference the xml file? Apparently the content of the xml file should look
>> like this one [
>> http://code.metager.de/source/xref/lib/gdal/frmts/wms/frmt_wms_openstreetmap_tms.xml
>> By these instructions [http://www.gdal.org/frmt_wms.html] I can not look
>> through.
>> Thank you very much in advance for answering!
>>  *Gesendet:* Montag, 09. Februar 2015 um 16:38 Uhr
>> *Von:* "Brent Fraser" <bfraser at geoanalytic.com>
>> <http://bfraser@geoanalytic.com>
>> *An:* geo.graefin at web.de, "GeoMOOSE Users List"
>> <geomoose-users at lists.osgeo.org> <http://geomoose-users@lists.osgeo.org>
>> *Betreff:* Re: Aw: Re: [Geomoose-users] print osm tiles
>>  Geograefin,
>>   Check your "frmt_wms_openstreetmap_tms.xml" file is working by using
>> gdal_translate (or gdalinfo) command line program.
>> Best Regards,
>> Brent Fraser
>> On 2/9/2015 7:31 AM, geo.graefin at web.de wrote:
>> Dear Brent Fraser,
>> in addition to the post you listed below, I have created a map file
>> (my_osm.map), to support the printing of osm tiles.
>> MAP
>>  #---------------------------------MAPFILEHEADER----------------------------------
>>     NAME 'background'
>>     STATUS ON
>>     DEBUG 5
>>     CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
>>     #EXTENT 1190889 6412149 1987057 6860988
>>     #SIZE 100 100
>>     #UNITS METERS
>>     #IMAGETYPE PNG
>>     PROJECTION
>>         'init=epsg:3857'     #projection of the map
>>     END
>>     OUTPUTFORMAT
>>         NAME png
>>         DRIVER "GD/PNG"
>>         MIMETYPE "image/png"
>>         IMAGEMODE PC256
>>         EXTENSION "png"
>>     END
>>     INCLUDE "../../geomoose_globals.map"
>>  #-----------------------------------WEB-SECTION----------------------------------
>>     WEB
>>         IMAGEPATH "/ms4w/tmp/ms_tmp/"
>>         IMAGEURL "/ms_tmp/"
>>         METADATA
>>             WMS_TITLE "open street map"
>>             WMS_ABSTRACT "Open Street Map Kacheln"
>>             WMS_ONLINERESOURCE "http://localhost/cgi-bin/mapserv?
>>                 map=/geomoose2/maps/demo/test/angebote/my_osm.map"
>>             WMS_SRS "EPSG:3857"        #projection of the service
>>             WMS_ENABLE_REQUEST "*"
>>         END
>>     END
>>  #-------------------------------------LAYER--------------------------------------
>>       LAYER
>>         NAME 'my_osm'
>>         DATA "frmt_wms_openstreetmap_tms.xml"
>>         STATUS ON
>>         TYPE RASTER
>>         PROCESSING "OVERSAMPLE_RATIO=1"
>>         PROCESSING "LOAD_FULL_RES_IMAGE=NO"
>>         UNITS METERS
>>         METADATA
>>             WMS_TITLE "open street map tiles"
>>         END
>>         PROJECTION
>>             "proj=merc" "a=6378137" "b=6378137" "lat_ts=0.0" "lon_0=0.0"
>> "x_0=0.0" "y_0=0" "k=1.0" "units=m" "nadgrids=@null" "no_defs"
>>         END
>>       END
>> END     #end map
>> Are the settings correct, the coordinate systems, too?
>> And the settings in mapbook.xml are these:
>>     <map-source name="background" type="mapserver">
>>         <file>./test/angebote/my_osm.map</file>
>>         <layer name="my_osm" status="on"/>
>>     </map-source>
>>      <layer title="Mein OSM" src="background/my_osm" legend="false"
>> fade="false" unfade="false"/>
>> I would be very grateful if you could check this! Currently, there is
>> just a white display, when I turn on the layer.
>> Thank you very much!
>>  *Gesendet:* Mittwoch, 04. Februar 2015 um 18:56 Uhr
>> *An:* geo.graefin at web.de, geomoose-users at lists.osgeo.org
>>  There's some info on a work-around:
>> http://osgeo-org.1560.x6.nabble.com/Geomoose-users-Printing-tt4928024.html
>> but the results are not very good.
>> Best Regards,
>> Brent Fraser
>> On 2/4/2015 3:45 AM, geo.graefin at web.de wrote:
>>  Hello,
>> is there a current solution to print open street map tiles in GeoMOOSE?
>> Thank you for your answers!
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150214/e81d1e95/attachment-0001.html>
More information about the Geomoose-users mailing list
