[Geomoose-users] GeoMOOSE on Windows
Dan Little theduckylittle at gmail.com
Thu Feb 19 11:29:46 PST 2015
Hi Mark,
Try contacting Jeff McKenna.  Jim and I talked to him at FOSS4G and he
has a new version coming shortly or sorta-ready.  You might be able to
get a beta of that from him and he may actually be looking for some
help and/or sponsorship to get the release out.
I've not used OSGeo4W, I really only use Windows for IE testing.
GeoMOOSE runs well in a virtualized environment if y'all are a VSphere
shop then sometimes it's a little lower threshold to get a linux
instance up and running.  It also runs well on
EC2/RackSpace/Linode/DigitalOcean.
Finally, if you want to move to Linux and/or can move to a hosted
solution, you could backchannel David Bitner and I -- dbSpatial
provides such services and we could put together an estimate for you.
On Thu, Feb 19, 2015 at 2:15 PM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I am considering upgrading our GeoMOOSE application.  We are a Windows shop
> so in the past I had used MS4W.  However, since the last MS4W update was
> nearly 3 years ago I can only assume that that project is dead.
> I was just wondering if I should either:
> ·         Continue to limp on the current MS4W and wait for an upgrade.
> ·         Consider something else such as OSGeo4W.  Has anyone had any
> success with OSGeo4W?
> ·         Beg to get a Linux box set up.  – This might be a tough challenge.
> Thank You for any advice
> Mark Volz
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
