[Geomoose-users] Problem in query.php if layer SRS different from map SRS
Brent Fraser bfraser at geoanalytic.com
Mon Jul 27 11:02:05 PDT 2015
bobb,
   No, i would replace the UTM parcel data with a lat/lon parcel
dataset.  The would prevent any pre-release testing short-cuts.
Best Regards,
Brent Fraser
On 7/27/2015 11:42 AM, Basques, Bob (CI-StPaul) wrote:
> All,
> Should we use the same data in both projections, or two different
> datasets?  I would need to search around for another dataset complete
> with attributes for searching on.
> I think it would be better to have an entirely separate dataset with
> another projection as an example.
> The current Parcel dataset is already vetted for redistribution, and
> adding more data to it may take a bit to get going.  Another chunk of
> data alongside of it would be nice, use a different color, different
> projection for sourcing, etc.
> bobb
>> On Jul 27, 2015, at 12:38 PM, Brent Fraser <bfraser at geoanalytic.com
>> <mailto:bfraser at geoanalytic.com>> wrote:
>> Bobb,
>>   Yes! Change the parcel data to EPSG:4326 and test the rendering,
>> Identify, Select Features, Search Parcels, Printing,  and Feature
>> Report functions (that would likely decrease my support workload by 80%).
>> Best Regards,
>> Brent Fraser
>> On 7/27/2015 8:17 AM, Basques, Bob (CI-StPaul) wrote:
>>> All,
>>> I wonder if it wouldn’t be prudent to include data from more than
>>> one projection in order to insure that all reprojection conversions
>>> are working.
>>> bobb
>>>> On Jul 26, 2015, at 12:37 PM, TC Haddad <tchaddad at gmail.com> wrote:
>>>> Just as an overall comment, there are 2 very distinct user groups
>>>> for the demo - people who only care about Web Mercator stuff
>>>> working, and people who are trying to work in a local projection.
>>>> What we have in the demo is working pretty well for the first
>>>> group, and it is a bit unfriendly to beginners in the second group,
>>>> as projections show up in multiple places where beginners are
>>>> likely to run into trouble (e.g. even setting up your zoom levels
>>>> in the Mapbook.xml). It's compounded if a user runs into a bug, and
>>>> doesn't know it's a bug.
>>>> Probably worth a review of the docs to see how we might improve in
>>>> this area...
>>>> Tanya
>>>> On Sun, Jul 26, 2015 at 10:12 AM, Brent Fraser
>>>> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>>>>     Tanya,
>>>>       Just by looking at the code in Github I see that there is
>>>>     still no re-projection of the extent before the query call, so
>>>>     i expect that is is still broken (but I will try v2.8).  Now
>>>>     that I'm getting results back I ran into the "zoom to results"
>>>>     bug you've referenced, so that saved me some time.  Thanks!
>>>>     Personally, I think the parcel data in our demo should be in
>>>>     EPSG:4326 so we can discover these problems in our testing
>>>>     before release.
>>>>     Best Regards,
>>>>     Brent Fraser
>>>>     On 7/26/2015 10:57 AM, TC Haddad wrote:
>>>>>     There was a bug that was fixed recently that may relate:
>>>>>     https://github.com/geomoose/geomoose/issues/90
>>>>>     You could try grabbing the relevant changes to query.php:
>>>>>     https://github.com/geomoose/geomoose-services/commit/dacfa7e2648c5bcd3ec38308cb1199621a07c390
>>>>>     Or you could try a 2.8 install to see if the same problem is
>>>>>     present (before filing a new issue...).
>>>>>     On Sun, Jul 26, 2015 at 9:32 AM, Brent Fraser
>>>>>         Hi Developers (and others),
>>>>>           While debugging a user's problem with using his data
>>>>>         with query.php, I see that line 376 in github (or line
>>>>>         420-ish in GM 2.7.1):
>>>>>             $ext = $queryLayer->getExtent();
>>>>>         then the layer's extent is used for the query a little later:
>>>>>         $queryLayer->queryByRect($ext);
>>>>>         This fails to find any features since in my case the
>>>>>         coordinate systems of the map and layer are different, and
>>>>>         the queryByrect must be done using a rectangle in the
>>>>>         MAP's SRS not the LAYER's SRS.  I did a little hack to
>>>>>         re-project the extent just before the queryByRect:
>>>>>                             // re-project the layer's extent into
>>>>>         the map SRS for querying:
>>>>>         $map_projection_def = $map->getProjection();
>>>>>         $map_projection_obj =
>>>>>         ms_newProjectionObj($map_projection_def);
>>>>>         if($queryLayer->getProjection() != NULL) {
>>>>>           $projection = $queryLayer->getProjection();
>>>>>         if($projection != NULL) {
>>>>>           # reproject the query shape as available.
>>>>>           $projection = ms_newProjectionObj($projection);
>>>>>         if($projection) {
>>>>>         $ext->project($projection, $map_projection_obj);
>>>>>         if($DEBUG) {
>>>>>         error_log(implode(',',
>>>>>         array($ext->minx,$ext->miny,$ext->maxx,$ext->maxy)));
>>>>>         error_log("<br/>extent for query in map SRS.<br/>");
>>>>>         I thought I would get comments before filing an Issue.
>>>>>         So any comments?
>>>>>         Best Regards,
>>>>>         Brent Fraser
>>>>>         _______________________________________________
>>>>>         Geomoose-users mailing list
>>>>>         Geomoose-users at lists.osgeo.org
>>>>>         <mailto:Geomoose-users at lists.osgeo.org>
>>>>>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150727/8fa59620/attachment-0001.html>
More information about the Geomoose-users mailing list
