[Geomoose-users] geomoose-user
Simon Gathuri simon.gathuri at yahoo.com
Fri Jul 24 19:49:24 PDT 2015
I have attached the mapfile and mapbook. Kindly help me to fix this search
issue. Thanxs
     On Friday, July 24, 2015 8:46 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
  Simon,
   You don't give us much detail to go on.   How much debugging have you done?  what is the full definition of your Search-parcel service in your mapbook?
 Best Regards,
Brent Fraser On 7/21/2015 9:43 PM, Simon Gathuri wrote:
     Hi, I dont know where am going wrong in my search result check my code and  advice
  =====.map============================================================== # drill-down identify service record.                                                 'identify_record'              'templates/projeclatlongt_identify.html'                                                   # query.php / "Search Parcels" functionality.                                                 'itemquery'         'templates/search_result.html'                                                 'itemquery-filter'             '/.*[qstring].*/i'                                                  'qstring_validation_pattern' '.'        # Feature reports are stored in the conf/feature_report directory.                                                 'feature_report' 'parcel.xml'                                                   'select_record'  'templates/select_result.html'                                                 'select_header' 'templates/select_header.html'                                                 'popups' 'parcels_popup.html'               "identify_record"       "projeclatlongt_identify.html" #            "popups"                "projeclatlongt_popups.html"         END # of METADATA   ========================search_result.html============================================== <!-- MapServer Template --> <b>PLOT NO:</b> <a data-pin="[PLOTNO_1]" id="gm-parcel-[PLOTNO_1]" class='sprite-control  sprite-control-find-selected' style="padding-left: 22px" parcel-shape="[shpxy]" href="javascript:GeoMOOSE.zoomToPointsList(dojo.byId('gm-parcel-[PLOTNO_1]').getAttribute('parcel-shape'),'EPSG: 3857');">[PLOTNO_1]</a><br/> <b>PLOT_NO2:</b> [PLOTNO_1]<br/> <hr/>     =============================mapbook============================================ <url>php/query.php</url>            <step type="input">                 <input type="hidden" name="highlight" value="true"/>                 <input type="hidden" name="mode" value="search"/>                   <input type="hidden" name="layer0" value="parcels/projeclatlongt"/>                 <input type="hidden" name="template0" value="itemquery"/>                   <input type="select" name="fieldname0" title="Search By:">                      <optionvalue="PLOTNO_1">LR NO</option>                      <option value="PAID">Status</option>                 </input>
        On Friday, July 17, 2015 2:58 AM, Brent Fraser <bfraser at geoanalytic.com> wrote:
    Simon,
   I really appreciate the offer.  Please feel free to donate to the Humanitarian OpenStreetMap Team (http://hotosm.org/donate).   You can also support GeoMoose by promoting it locally in your area,  helping others on the Geomoose email list, or by writing documentation.
   And have a look at OSGeo (http://www.osgeo.org/); there are lots of other open source geo-spatial projects you can contribute to.
 Thanks again and enjoy GeoMoose!
 Best Regards,
Brent Fraser  On 7/16/2015 1:15 PM, Simon Gathuri wrote:
 Thanxs alot .Am very glad. It has worked very well. How can I  send some cash to support your good work???
       On Thursday, July 16, 2015 7:00 AM,  Brent Fraser <bfraser at geoanalytic.com> wrote:
    Here's a mapbook with my layers removed.
 Best Regards,
Brent Fraser  On 7/15/2015 8:25 PM, Simon  Gathuri wrote:
  Thanxs alot.
 Almost there. But I get a  Blank map as attached. What might be the  cause of this?
 send me the template  folder that has
 (projeclatlongt_identify.html"
 ( "projeclatlongt_popups.html  )
 ================================ErrorLog================================
 [Thu Jul 16 05:15:51  2015].806000 CGI Request 1 on process  4672
 [Thu Jul 16 05:15:51  2015].810000 msDrawMap(): rendering  using outputformat  named png (AGG/PNG).
 [Thu Jul 16 05:15:51  2015].810000 msDrawMap(): WMS/WFS set-up  and query, 0.000s
 [Thu Jul 16 05:15:51  2015].812000 msDrawMap(): Layer 0  (projeclatlongt), 0.002s
 [Thu Jul 16 05:15:51  2015].812000 msDrawMap(): Drawing Label  Cache, 0.000s
 [Thu Jul 16 05:15:51  2015].812000 msDrawMap() total time:  0.006s
 [Thu Jul 16 05:15:52  2015].164000 msSaveImage(stdout) total time:  0.352s
 [Thu Jul 16 05:15:52  2015].164000 mapserv request  processing time (msLoadMap not incl.): 0.358s
 [Thu Jul 16 05:15:52  2015].164000 msFreeMap(): freeing map at  024C1FD8.
 [Thu Jul 16 05:15:52  2015].164000 freeLayer(): freeing layer  at 024CAF38.
 [Thu Jul 16 05:15:52  2015].308000 CGI Request 1 on process  3100
 [Thu Jul 16 05:15:52  2015].308000 msSaveImage(stdout) total time:  0.000s
 [Thu Jul 16 05:15:52  2015].308000 mapserv request  processing time (msLoadMap not incl.): 0.000s
 [Thu Jul 16 05:15:52  2015].308000 msFreeMap(): freeing map at  025D1FD8.
 [Thu Jul 16 05:15:52  2015].309000 freeLayer(): freeing layer  at 025DADC8.
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150725/580b0e59/attachment-0001.html>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150725/580b0e59/attachment-0001.xml>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150725/580b0e59/attachment-0001.obj>
More information about the Geomoose-users mailing list
