[Geomoose-users] Feature Report error with Identify Tool
Fernando nando_gcia at hotmail.com
Tue Jun 2 04:35:34 PDT 2015
Thanks all for your contributions. Incredibly the first error has disappeared with only capitalize the dfx_text field in identify.html file:
<!-- MapServer Template -->
<tr bgcolor="#DEE5EB"><td colspan="2"><b><u>ESPACIOS</u></b></tr><tr>
<td align="right"><b>IDENTIFICADOR:</b></td>
<td>[dxf_text] <a href="javascript:GeoMOOSE.startService('feature_report', {'DXF_TEXT' : '[dxf_text]', 'src' : 'edificio_c2_espacios/C2-ALBERT_EINSTEIN'})">Report</a></td>
</tr>
<tr>
<td align="right"><b>CONTENIDO:</b></td>
<td>[contenido]</td>
</tr>
But still appears error:
Warning: mapObj::setExtent(): [MapServer Error]: setExtent(): Given map extent is invalid. Check that it is in the form: minx, miny, maxx, maxy
 in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 100
Fatal error: Uncaught exception 'MapScriptException' in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php:100
Stack trace:
#0 C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php(100): mapObj->setExtent(0, 0, 0, 0)
#1 {main}
  thrown in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 100
Line 100 of the file says:
$mapObj->setExtent($shape->bounds->minx,$shape->bounds->miny,$shape->bounds->maxx,$shape->bounds->maxy);
but if I change that row so manually for example set to the initial extend:
$mapObj->setExtent(358836,4186265,359163,4186624);
The error disappears, and finally load the popup with the 3 options:
View in a new Window / Tab
Download
Close this Window
but the more errors appear then:
Warning: Invalid argument supplied for foreach() in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 128
<results><script>GeoMOOSE.download("print_14332443998300","pdf");</script><html></html></results>
Why the error occurs on line 100 of feature_report.php file?
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150602/d2e3822c/attachment.html>
More information about the Geomoose-users mailing list
