[Geomoose-users] GDB layer problems - Pink Screen
TC Haddad tchaddad at gmail.com
Tue Jun 2 12:40:09 PDT 2015
Just a check:
is "lafSchools_anno" refferring to an ESRI Annotation layer? because I
don't think OGR supports those types of layers.
Tanya
On Tue, Jun 2, 2015 at 10:33 AM, Joshua Meyer <jmeyer at lcsheriff.com> wrote:
> I have tried to add layers from an ESRI geodatabase.  The following error
> is received: msOGRFileOpen(): OGR error. Open failed for OGR connection in
> layer `ESN'.  File not found or unsupported format.  I originally exported
> the layers to shapefiles for testing and they worked.  I have tested each
> map file using shp2img with success on each individual layer.  However,
> when loading from the mapbook.xml I received the above error.
> The gdb file is located in the same folder as the map file.
> LAYER
>     NAME lafSchools
>     TYPE POINT
>     CONNECTIONTYPE OGR
>     CONNECTION "./Lafayette.gdb"
>     DATA "Schools"
> Below is the mapbook entry.
> <map-source name="lafSchools" type="mapserver">
>         <file>./lafayette/ESN/school.map</file>
>         <layer name="lafSchools" status="off"/>
>         <layer name="lafSchools_anno" status="off"/>
>         <param name="FORMAT" value="image/png; mode=8bit"/>
> </map-source>
> <layer title="Lafayette Schools" src="lafSchools/lafSchools"
> popups="false" minscale="3000" maxscale="20000">
> </layer>
> Joshua Meyer
> Lafayette County Sheriff's Office GIS
> 107 S 11th St
> Lexington, MO 64067
> Phone: 660-259-2796
> Cell: 660-259-1234
> Fax: 660-259-2545
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150602/9372341f/attachment.html>
More information about the Geomoose-users mailing list
