[Geomoose-users] GDB layer problems - Pink Screen
Joshua Meyer jmeyer at lcsheriff.com
Tue Jun 2 13:01:38 PDT 2015
Yes, ogrinfo works.  It connects successfully and I am able to see the data.  After I verified this was working, I tested the associated .map files with shp2img.  Shp2img outputs the data to the image and I am able to see data.
Joshua Meyer
Lafayette County Sheriff's Office GIS
107 S 11th St
Lexington, MO 64067
Phone: 660-259-2796
Cell: 660-259-1234
Fax: 660-259-2545
Sent: Tuesday, June 02, 2015 2:54 PM
To: Joshua Meyer
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] GDB layer problems - Pink Screen
Ok, that was just a guess :)
Do you happen to know if your version of gdal/ogr has the  FileGDB API library installed?
That is listed as a requirement on the OGR supported vector formats page:
http://www.gdal.org/ogr_formats.html
It sounds like if you have OGR 1.11 you *should* be ok for reading:
http://www.gdal.org/drv_filegdb.html
You could try using the command line tool "ogrinfo" to test your connection, using some of the steps outlined on this page (under the "OGRINFO Examples" section):
http://mapserver.org/input/vector/filegdb.html
That might help narrow down where your problem is originating...
Tanya
On Tue, Jun 2, 2015 at 12:40 PM, Joshua Meyer <jmeyer at lcsheriff.com> wrote:
It is not an ESRI annotation layer.  It is pointing to the same layer.
Joshua Meyer
107 S 11th St
Lexington, MO 64067
Phone: 660-259-2796
Cell: 660-259-1234
Fax: 660-259-2545
Sent: Tuesday, June 02, 2015 2:40 PM
To: Joshua Meyer
Just a check:
is "lafSchools_anno" refferring to an ESRI Annotation layer? because I don't think OGR supports those types of layers.
Tanya
On Tue, Jun 2, 2015 at 10:33 AM, Joshua Meyer <jmeyer at lcsheriff.com> wrote:
I have tried to add layers from an ESRI geodatabase.  The following error is received: msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `ESN'.  File not found or unsupported format.  I originally exported the layers to shapefiles for testing and they worked.  I have tested each map file using shp2img with success on each individual layer.  However, when loading from the mapbook.xml I received the above error.
The gdb file is located in the same folder as the map file.
LAYER
    NAME lafSchools
    TYPE POINT
    CONNECTIONTYPE OGR
    CONNECTION "./Lafayette.gdb"
    DATA "Schools"
Below is the mapbook entry.
<map-source name="lafSchools" type="mapserver">
        <file>./lafayette/ESN/school.map</file>
        <layer name="lafSchools" status="off"/>
        <layer name="lafSchools_anno" status="off"/>
        <param name="FORMAT" value="image/png; mode=8bit"/>
</map-source>
<layer title="Lafayette Schools" src="lafSchools/lafSchools" popups="false" minscale="3000" maxscale="20000">
</layer>
Joshua Meyer
107 S 11th St
Lexington, MO 64067
Phone: 660-259-2796
Cell: 660-259-1234
Fax: 660-259-2545
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150602/7d6f909e/attachment.html>
More information about the Geomoose-users mailing list
