[Geomoose-users] Feature Report error with Identify Tool
Fernando nando_gcia at hotmail.com
Tue Jun 2 23:13:30 PDT 2015
Brent sorry but your solution doesn't work:
    <service name="feature_report" display="false" keep-others="true">
        <url>php/feature_report.php</url>
        <input type="hidden" name="layers" value="edificio_c2_espacios/C2-ALBERT_EINSTEIN"/>
        <input type="hidden" name="src"/>
        <input type="hidden" name="DXF_TEXT"/>
    </service>
Still Appears error:
Warning: mapObj::setExtent(): [MapServer Error]:
            setExtent(): Given map extent is invalid. Check that it is
            in the form: minx, miny, maxx, maxy
             in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on
            line 100
            Fatal error: Uncaught exception 'MapScriptException' in
            C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php:100
            Stack trace:
            #0
            C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php(100): mapObj->setExtent(0,
              0, 0, 0)
            #1 {main}
              thrown in
            C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line
            100
I'm a little lost, what is happening?
Date: Tue, 2 Jun 2015 07:35:29 -0600
To: nando_gcia at hotmail.com; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Feature Report error with Identify Tool
    The errors mean that the shape/feature is not found, so the extents
    are not valid and the shape/feature has no values.
    Change your feature _report service in your mapbook.xml to:
      keep-others="true">
      value="lmic/fsa"/>
        </service>
    This will ensure the JavaScript that handles the service call will
    send the DXF_TEXT value to the feature_report.php.
    Best Regards,
Brent Fraser
    On 6/2/2015 5:35 AM, Fernando wrote:
      Thanks
            all for your contributions. Incredibly the first error has disappeared with only
            capitalize the dfx_text field in identify.html file:
            <!-- MapServer Template -->
            <tr bgcolor="#DEE5EB"><td
colspan="2"><b><u>ESPACIOS</u></b></tr><tr>
            <td
            align="right"><b>IDENTIFICADOR:</b></td>
            <td>[dxf_text] <a
            href="javascript:GeoMOOSE.startService('feature_report', {'DXF_TEXT'
            : '[dxf_text]', 'src' :
'edificio_c2_espacios/C2-ALBERT_EINSTEIN'})">Report</a></td>
            </tr>
            <tr>
            <td
            align="right"><b>CONTENIDO:</b></td>
            <td>[contenido]</td>
            </tr>
        But still appears error:
            line 100
            Stack trace:
            #0
              0, 0, 0)
            #1 {main}
              thrown in
            100
          Line 100 of the file says:
$mapObj->setExtent($shape->bounds->minx,$shape->bounds->miny,$shape->bounds->maxx,$shape->bounds->maxy);
          but if I change that row so manually for example set to
            the initial extend:
        $mapObj->setExtent(358836,4186265,359163,4186624);
        The error disappears, and finally load the popup with the
            3 options:
          View in a new Window / Tab
          Download
          Close this Window
          but the more errors appear then:
        Warning: Invalid argument supplied for foreach() in
        C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 128
<results><script>GeoMOOSE.download("print_14332443998300","pdf");</script><html></html></results>
        Why
            the error occurs on line 100 of feature_report.php file?
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150603/ccf469f4/attachment.html>
More information about the Geomoose-users mailing list
