[Geomoose-users] problem projecting a WMS
James Klassen klassen.js at gmail.com
Tue Mar 3 12:19:34 PST 2015
Cool.
On Mar 3, 2015 2:18 PM, "Bistrais, Bob" <Bob.Bistrais at maine.gov> wrote:
>  Think I got it now.  Once I updated the URL, the problem was with the
> layer name.  I had the layer name as “Wetlands” (that would seem logical).
> But the actual layer name in the WMS is “1”.  I updated mapbook.xml
> accordingly, and it works.
> I hope this might help others out there.  If you use USFWS NWI service,
> please be aware of the layer names!
> Bob
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Bistrais, Bob
> *Sent:* Tuesday, March 03, 2015 3:08 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] problem projecting a WMS
> Correction- I forgot to update the layer name for the Catalog checkbox.
> Now that I’ve done that, I get the dreaded pink screen.  Still
> investigating on my end, but something’s weird about this updated NWI
> service.  Any thoughts?
> mailto:geomoose-users-bounces at lists.osgeo.org
> <geomoose-users-bounces at lists.osgeo.org>] *On Behalf Of *Bistrais, Bob
> *Sent:* Tuesday, March 03, 2015 2:48 PM
> *Subject:* [Geomoose-users] problem projecting a WMS
> Hello all,
> I needed to update my NWI layer references because of an apparent change
> by USFWS with the NWI service.  I thought it would be as simple as changing
> the URL and/or layer name.  But now the NWI layer does not show at all.  I
> am not getting any error messages in Firebug.
> Our applications use EPSG:26919 as an SRS.  The NWI services supports 84,
> 4326, 3857, and 102100.  In the past I have made this work simply by
> setting the map-source projection parameter, but it doesn’t seem to be
> working now.
> My suspicion is that that the layer is not being reprojected to the
> application’s projection, but this worked in the past.  This particular
> application is using GeoMoose 2.6RC1.  Here is the code from the
> mapbook.xml:
>                 <map-source name="nwi" type="wms" reference="false"
> tiled="false" projection='EPSG:26919'>
>                                 <url>
> http://107.20.228.18/ArcGIS/services/Wetlands/MapServer/WMSServer?</url>
>                                 <layer name="Wetlands" queryable="true"
> status="off"/>
>                                                 <param name="format"
> value="image/png"/>
>                                                 <param name="TRANSPARENT"
> value="TRUE"/>
>                                                 <param name="STYLES"
> value=""/>
>                 </map-source>
> If it helps, here is the URL to USFWS’s NWI page:
> http://www.fws.gov/wetlands/Data/Web-Map-Services.html
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150303/100eab09/attachment.html>
More information about the Geomoose-users mailing list
