[Geomoose-users] REST Services
Tim Hennig timhbellevue at gmail.com
Thu Nov 5 14:29:34 PST 2015
Hi Mark,
I was able to call the REST service by name.  I forgot to add the src =
"ags/sirens".   Everything works (no errors in Firebug) except the
projection/overlay.
I did add the projection='EPSG:2929' within the map-source tag.  This did
not help.
I tried all the image formats to see if by chance it would overlay.  No
luck.
I am stumped.
Thanks,
Tim Hennig
Sent: Thursday, November 05, 2015 8:27 AM
To: Tim Hennig; geomoose-users at lists.osgeo.org
Subject: RE: [Geomoose-users] REST Services
Tim,
1)      It looks like you did not specify a projection, therefore ArcGIS
will serve the map but It apparently will not serve it in the same
projection you are using.  I think it defaults to web Mercator now?  Try
adding the projection and maybe things will work.
2)      In your code snippet you referenced "ags/sirens" instead of layer
"1".  Please let me know if you can get GeoMOOSE to work with ArcServer by
referencing the layer by name instead of the number.
3)      I forgot to mention previously that in GeoMOOSE that perhaps all the
tools such as buffering, identify, etc work through MapServer.  You can
display layers from ArcServer, but that is about all you can do with
ArcServer tools.
Sincerely,
Mark Volz, GISP
From: Tim Hennig [mailto:timhbellevue at gmail.com]
Sent: Thursday, November 05, 2015 7:58 AM
To: Mark Volz; geomoose-users at lists.osgeo.org
Hi Mark,
Thanks for the reply!
I see what I did wrong..
                <layer title="Test" src="Sirens" show-legend="false"
legend="false" fade="false" unfade="false"/>
                src = "ags/sirens"
I set the source wrong.  It works now!
However, I might have a projection issue, not sure how.  The REST data is
not overlaying.  Hmmmm..
Tim Hennig
Sent: Wednesday, November 04, 2015 4:31 PM
Tim,
For some reason ArcGIS likes to use numbers for layer names.
                <map-source name="PictometryArcServer" type="wms"
reference="false" projection='EPSG:103749' tiled="true" width='256'
height='256' transition_Effect="resize">
<url>http://gis.lyonco.org/arcgis/services/LyonGIS/Basemap_AirPhotos/MapServ
er/WMSServer?
<http://gis.lyonco.org/arcgis/services/LyonGIS/Basemap_AirPhotos/MapServer/W
MSServer?%3c/url> </url>
                                                <layer name="1"/>
                                                <layer name="2"/>
                                                <layer name="3"/>
                                                <layer name="4"/>
                                                <param name="STYLES"
value=""/>
                </map-source>
Sincerely,
Mark Volz, GISP
From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On
Behalf Of Tim Hennig
Sent: Wednesday, November 04, 2015 3:59 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] REST Services
Hi Everyone,
I am trying to incorporate a ArcGIS REST Service from a county server.
I am having no luck with this, can anyone help me regarding this.  Here is
my test syntax.
                <map-source name="ags" type="ags">
<url>http://maps.gis.co.brown.wi.us/arcgis/rest/services/Sirens/MapServer/Ex
port
<http://maps.gis.co.brown.wi.us/arcgis/rest/services/Sirens/MapServer/Export
%3c/url> </url>
                                <layer name="Sirens"/>
                                <param name="FORMAT" value="PNG"/>
                </map-source>
This is my error message from FireBug (No pink screen).
TypeError: this._modalconnects is undefined
...ferred){this._fadeOutDeferred.cancel();}this._modalconnects.push(dojo.con
nect(wi...
dojo.js (line 14, col 297062)
Thank you,
Tim Hennig
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20151105/526f63c7/attachment.html>
More information about the Geomoose-users mailing list
