[Geomoose-users] Geomoose User
Brent Fraser bfraser at geoanalytic.com
Sat Sep 19 13:15:01 PDT 2015
Have at look at the response from mapserver by using the debugger in
your browser.  Use the network tab in the debugger to show the request
made by Geomoose and the response by mapserver.  Typically if there is a
problem in the mapfile, mapserver will send an error message instead of
the expected graphic.  That's why there is a pink image displayed by
Geomoose (actually the OpenLayers tool kit used by Geomoose).
Please ask for help on the Geomoose email list
(http://www.geomoose.org/info/mailing_lists.html) so everyone can benefit.
Best Regards,
Brent Fraser
On 9/19/2015 10:35 AM, Antony Mwangi wrote:
> So far am able to do mapbook.xml configuration and able to work with
> demo data provided in geomoose.
> >From the demo data am able to add layers in geomoose catalog but now
> I want to work with my shapefiles (*that is my biggest challenge*).
> For Mapserver I have read a tutorial by Jeff McKenna. I can also
> export .map files from Qgis ie (File>>Web>>Mapserver Export).
> Before I  worked with geoserver, postgis,google maps and kml files but
> they have limited functionalities.
> I have some knowledge on Javascript, php and  can debug code with firebug
> My Main Aim of this project is that I want My Maps to be accessed
> online and also a user to be able to add points to postgres database.
> (*Kindly* help me display the shapefile i sent and assist me to know
> t*he possible errors I made*) If I manage this I will work on other layers
> On Saturday, September 19, 2015 5:19 PM, Brent Fraser
> <bfraser at geoanalytic.com> wrote:
> What have you done so far?  Which parts of the GeoMoose and Mapserver
> documentation have you read? Which skills do you have with JavaScript,
> web browser debugging, map projections, etc?
> What are your goals of your project?
> Best Regards,
> Brent Fraser
> On 9/19/2015 7:25 AM, Antony Mwangi wrote:
>> Thanxs : I have moved but this time i get a pink page. please assist
>> me in changing the mapfile
>> On Saturday, September 19, 2015 7:26 AM, Brent Fraser
>> <bfraser at geoanalytic.com> <mailto:bfraser at geoanalytic.com> wrote:
>> Your projection is wrong.
>> Move
>>     PROJECTION
>>         AUTO
>>     END # of PROJECTION
>> from the MAP section to the LAYER section
>> Best Regards,
>> Brent Fraser
>> On 9/18/2015 9:04 PM, Antony Mwangi wrote:
>>> Hi, Am a beginner in geomoose . Am trying to load a shapefile but I
>>> get a blank output in my browser. Please tell me where am getting wrong.
>>> I have attached the shapefile , mapbook and the mapfile. I will
>>> highly appreciate.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150919/738982d6/attachment.html>
More information about the Geomoose-users mailing list
