[Geomoose-users] Geomoose buttons not working
Janet Maina madamjanet92 at gmail.com
Thu Dec 1 12:30:56 PST 2016
Hey am having a problem when I host  geomoose in unix environment.  some
buttons like print, identify don't work.  check in '
http://www.waterresources.co.ke/data/htdocs/geomoose.html'
i get this error
*The service you called did not return valid XML.* If you are the system
administrator, you should look into this, if you are not the system
administrator you should tell them about this.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161201/4d052fd2/attachment.html>
More information about the Geomoose-users mailing list
