[Geomoose-users] Geomoose buttons not working
Dan Little theduckylittle at gmail.com
Fri Dec 2 11:34:50 PST 2016
How was the application install? MS4W? Which instructions did you use?
On Thu, Dec 1, 2016 at 3:09 PM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> On Thu, Dec 1, 2016 at 12:41 PM, Caitlin Christenson
> <caitlinprodoehl at co.stevens.mn.us> wrote:
>> I think there’s an issue in your configuration file.
>> From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On
>> Behalf Of Janet Maina
>> Sent: Thursday, December 01, 2016 2:31 PM
>> To: geomoose-users at lists.osgeo.org
>> Subject: [Geomoose-users] Geomoose buttons not working
>> Hey am having a problem when I host  geomoose in unix environment.  some
>> buttons like print, identify don't work.  check in
>> 'http://www.waterresources.co.ke/data/htdocs/geomoose.html'
>> i get this error
>> The service you called did not return valid XML. If you are the system
>> administrator, you should look into this, if you are not the system
>> administrator you should tell them about this.
> Troubleshooting with Firebug or something similar might help.  Using
> Firebug, I found this response to the search error:
> <br />
> <b>Fatal error</b>:  Call to undefined function ms_newprojectionobj()
> in <b>/home/gene/webapps/test/data/htdocs/php/query.php</b> on line
> <b>31</b><br />
> Identify:
> <br />
> <b>Fatal error</b>:  Call to undefined function ms_shapeObjFromWkt()
> in <b>/home/gene/webapps/test/data/htdocs/php/identify.php</b> on line
> <b>96</b><br />
> print:
> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
> <html><head>
> <title>404 Not Found</title>
> </head><body>
> <h1>Not Found</h1>
> <p>The requested URL /mapserver.cgi was not found on this server.</p>
> </body></html>
> <br />
> <b>Fatal error</b>:  Call to undefined function ms_newMapObj() in
> <b>/home/gene/webapps/test/data/htdocs/php/print_util.php</b> on line
> <b>301</b><br />
> This all seems to point to MapServer not being found or accessible.
> Firebug will help find these problems and find how to fix them.
> Best regards, Eli
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
