[Geomoose-users] Geomoose buttons not working
James Klassen klassen.js at gmail.com
Mon Dec 5 08:25:03 PST 2016
Just a guess but I don't see anything building or installing php mapscript.
On Dec 5, 2016 09:36, "Dan Little" <theduckylittle at gmail.com> wrote:
> Please keep all of your responses going to the user's list in case
> future users have the same problems.
> This looks like you are using Linux.  Which distribution are you
> trying to install it on?
> On Sun, Dec 4, 2016 at 3:23 AM, Janet Maina <madamjanet92 at gmail.com>
> wrote:
> > Here are the commands that I did to install mapserver but am using
> geomoose
> > 2.9
> > mkdir src
> > cd src
> > wget http://download.osgeo.org/mapserver/mapserver-6.2.2.tar.gz
> > tar -xf mapserver-6.2.2.tar.gz
> > cd mapserver-6.2.2
> > ./configure --prefix=$HOME --with-gif=no --with-fastcgi=no --with-proj
> > --with-gdal --with-ogr --with-postgis=/usr/bin/pg_config --with-wfs
> > make
> > make install
> > On Fri, Dec 2, 2016 at 10:34 PM, Dan Little <theduckylittle at gmail.com>
> > wrote:
> >> How was the application install? MS4W? Which instructions did you use?
> >> On Thu, Dec 1, 2016 at 3:09 PM, Eli Adam <eadam at co.lincoln.or.us>
> wrote:
> >> > On Thu, Dec 1, 2016 at 12:41 PM, Caitlin Christenson
> >> > <caitlinprodoehl at co.stevens.mn.us> wrote:
> >> >> I think there’s an issue in your configuration file.
> >> >> From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org]
> On
> >> >> Behalf Of Janet Maina
> >> >> Sent: Thursday, December 01, 2016 2:31 PM
> >> >> To: geomoose-users at lists.osgeo.org
> >> >> Subject: [Geomoose-users] Geomoose buttons not working
> >> >> Hey am having a problem when I host  geomoose in unix environment.
> >> >> some
> >> >> buttons like print, identify don't work.  check in
> >> >> 'http://www.waterresources.co.ke/data/htdocs/geomoose.html'
> >> >> i get this error
> >> >> The service you called did not return valid XML. If you are the
> system
> >> >> administrator, you should look into this, if you are not the system
> >> >> administrator you should tell them about this.
> >> > Troubleshooting with Firebug or something similar might help.  Using
> >> > Firebug, I found this response to the search error:
> >> > <br />
> >> > <b>Fatal error</b>:  Call to undefined function ms_newprojectionobj()
> >> > in <b>/home/gene/webapps/test/data/htdocs/php/query.php</b> on line
> >> > <b>31</b><br />
> >> > Identify:
> >> > <br />
> >> > <b>Fatal error</b>:  Call to undefined function ms_shapeObjFromWkt()
> >> > in <b>/home/gene/webapps/test/data/htdocs/php/identify.php</b> on
> line
> >> > <b>96</b><br />
> >> > print:
> >> > <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
> >> > <html><head>
> >> > <title>404 Not Found</title>
> >> > </head><body>
> >> > <h1>Not Found</h1>
> >> > <p>The requested URL /mapserver.cgi was not found on this server.</p>
> >> > </body></html>
> >> > <br />
> >> > <b>Fatal error</b>:  Call to undefined function ms_newMapObj() in
> >> > <b>/home/gene/webapps/test/data/htdocs/php/print_util.php</b> on line
> >> > <b>301</b><br />
> >> > This all seems to point to MapServer not being found or accessible.
> >> > Firebug will help find these problems and find how to fix them.
> >> > Best regards, Eli
> >> >> _______________________________________________
> >> >> Geomoose-users mailing list
> >> >> Geomoose-users at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161205/7664d37d/attachment.html>
More information about the Geomoose-users mailing list
