[Geomoose-users] Geomoose and mapcache
Jim Klassen klassen.js at gmail.com
Fri Dec 9 09:01:55 PST 2016
This is an example from probably 2011-2012.  Source WMS is just a normal
MapServer layer.  It is imagery so no worries about the metatiles to
attempt to get labels to work right.  I defined my own grid because I
found 512x512 tiles were more efficient than the 256x256 default which
required too many round trips to the server to fetch enough tiles to
fill a larger screen.
Map-Source:
    <map-source name='imagery' tiled='true' type='tms' width="512"
height="512" reference="off">
        <layer name="imagery at g512" title="Imagery"/>
        <url>https://my.server.com/mapcache/tms/</url>
        <param name="layername" value="imagery at g512"/>
    </map-source>
Map Cache:
<mapcache>
   <cache name="disk" type="disk">
      <base>/srv/data/mapcache/disk</base>
      <symlink_blank/>
   </cache>
   <source name="imagery" type="wms">
      <getmap>
         <params>
            <FORMAT>image/jpeg</FORMAT>
            <LAYERS>imagery_zone14,imagery_zone15,imagery_zone16</LAYERS>
         </params>
      </getmap>
      <http>
<url>http://mywmsserver/cgi-bin/mapserv?map=/datasets/maps/imagery_ortho.map</url>
      </http>
   </source>
  <grid name="utm15">
   <metadata>
      <title>UTM15</title>
   </metadata>
   <extent>176250.0589 1577463.0797 823749.9411 9106037.1690</extent>
   <srs>EPSG:26915</srs>
   <units>m</units>
   <size>512 512</size>
   <resolutions>2048 1024 512 256 128 64 32 16 8 4 2 1 0.6 0.3</resolutions>
  </grid>
  <grid name="g512">
   <metadata>
      <title>GoogleMapsCompatible</title>
<WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible</WellKnownScaleSet>
   </metadata>
   <extent>-20037508.3427892480 -20037508.3427892480 20037508.3427892480
20037508.3427892480</extent>
   <srs>EPSG:3857</srs>
   <srsalias>EPSG:900913</srsalias>
   <units>m</units>
   <resolutions>156543.0339280410 78271.51696402048 39135.75848201023
19567.87924100512 9783.939620502561 4891.969810251280 2445.984905125640
1222.992452562820 611.4962262814100 305.7481131407048 152.8740565703525
76.43702828517624 38.21851414258813 19.10925707129406 9.554628535647032
4.777314267823516 2.388657133911758 1.194328566955879 0.5971642834779395
0.29858214173896975296 0.14929107086948487648
0.07464553543474243824</resolutions>
    </grid>
   <tileset name="imagery">
      <metadata>
         <title>2008 Imagery</title>
         <abstract>2008 Imagery</abstract>
 <wms_metadataurl_href>http://my.server.org/metadata.xml</wms_metadataurl_href>
         <!--wms_metadataurl_type>FDGC</wms_metadataurl_type-->
         <!--wms_metadataurl_format>text/html</wms_metadataurl_format-->
      </metadata>
      <source>imagery</source>
      <cache>disk</cache>
      <grid>WGS84</grid>
      <grid>g512</grid>
      <grid>utm15</grid>
      <format>JPEG</format>
      <metatile>1 1</metatile>
      <metabuffer>0</metabuffer>
      <expires>3600</expires>
      <auto_expire>86400000000000</auto_expire>
   </tileset>
   <default_format>JPEG</default_format>
   <service type="wms" enabled="true">
      <full_wms>assemble</full_wms>
      <resample_mode>bilinear</resample_mode>
      <maxsize>4096</maxsize>
   </service>
   <service type="wmts" enabled="true"/>
   <service type="tms" enabled="true"/>
   <service type="kml" enabled="true"/>
   <service type="gmaps" enabled="true"/>
   <service type="ve" enabled="true"/>
   <service type="demo" enabled="true"/>
   <errors>report</errors>
   <lock_dir>/tmp</lock_dir>
</mapcache>
On 12/09/2016 10:25 AM, Brent Fraser wrote:
> Hey Jeff,
>   So far so good.  I've been able to edit the httpd.conf file (for
> some reason I had C:C: in my mapcache paths), restart Apache, and
> click on the Demo link under MapCache URLs heading  in the
> http://localhost page of MS4W.  The page showed me the demo data in
> the available tiling schemes.  Took me a while to figure out the HTML
> did not exist on disk as mapcache was generating these demo pages.
>   The next step will be a little more difficult as I need to configure
> MapCache and GeoMoose to show my data.  We should consider shipping
> our demo data with a pre-configured mapcache mapsource, or at least
> adding a page in our doc on it.
>   And many thanks for including mapcache in MS4W!
> Best Regards,
> Brent Fraser
> On 12/9/2016 5:52 AM, Jeff McKenna wrote:
>> Hi Brent,
>> Also as you travel down that path let me know if you think any tweaks
>> are needed into the distributed "/apps/mapcache/mapcache.xml" file in
>> MS4W.
>> -jeff
>> On 2016-12-08 10:33 PM, Brent Fraser wrote:
>>> Hi all,
>>>   I thought I would learn how to use mapcache.  Does any one have any
>>> example snippets from a mapbook.xml and mapcache's config.xml?
>>> Thanks!
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
