[Geomoose-users] Printing not working
James Klassen klassen.js at gmail.com
Wed Dec 14 18:15:25 PST 2016
Does the directory /tmp/out exist and is it writable by the user that the
php/web server code is running as?
(IIRC the PHP code doesn't create the directory.)
On Dec 14, 2016 20:11, "Kevin Grootendorst" <kgrootendorst at gmail.com> wrote:
Thanks for the feedback.  The path to my tmp file is the default path:
[paths]
root=/var/www/geomoose-2.8.1/maps/
mapserver_url=/cgi-bin/mapserv
temp=/tmp/out
I've experimented with different paths, but in each case, no file is
created in the directory.
Kevin
On Wed, Dec 14, 2016 at 12:41 PM, TC Haddad <tchaddad at gmail.com> wrote:
> Can you check that the path to your tmp directory is set correctly in
> local_settings.ini?
> On Wed, Dec 14, 2016 at 7:42 AM, Kevin Grootendorst <
>> Dear users,
>> I'm getting an error that I can't seem to decipher.  I'm trying to use
>> the Print tool in GeoMoose.  I'm presented with the title, size options,
>> etc., but when I click 'Go', I get the following error in Firebug:
>> [image: Inline image 2]
>> And in the Apache error log:
>> [Wed Dec 14 10:38:16.226718 2016] [:error] [pid 29622] [client
>> 24.157.101.143:65421] PHP Fatal error:  Uncaught exception
>> 'MapScriptException' with message 'Failed to open map file
>> "/tmp/out/sketch_148172989629622.map", or map file error.' in
>> /var/www/geomoose-2.8.1/htdocs/php/print_util.php:353\nStack trace:\n#0
>> /var/www/geomoose-2.8.1/htdocs/php/print_util.php(353):
>> ms_newMapObj('/tmp/out/sketch...', '/var/www/geomoo...')\n#1
>> /var/www/geomoose-2.8.1/htdocs/php/print_util.php(223):
>> renderVector(Array, 1600, 1400, Array)\n#2 /var/www/geomoose-2.8.1/htdocs/php/print.php(133):
>> renderImage(Object(DOMDocument), Array, 1600, 1400, Array, false)\n#3
>> {main}\n  thrown in /var/www/geomoose-2.8.1/htdocs/php/print_util.php on
>> line 353, referer: http://www.mysite.ca/geomoose/geomoose.html
>> In my experience, this is likely a path issue.  I have checked my tmp/out
>> folder and there is no file there, so perhaps that is throwing the error.
>> Any ideas?
>> Thanks, Kevin
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161214/96a45a84/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161214/96a45a84/attachment.png>
More information about the Geomoose-users mailing list
