[Geomoose-users] TypeError: GeoMOOSE.Layout is undefined
Dan Little theduckylittle at gmail.com
Thu Jan 21 09:54:38 PST 2016
GeoMOOSE's code base will not work with Dojo versions newer than 1.7 and
that's sorta borderline.  Dojo went through a major change in 1.6 and we
would need to make some major changes to the code base in order to make it
work with newer versions.  It's on the Roadmap for 3.0.
On Thu, Jan 21, 2016 at 11:53 AM, Bistrais, Bob <Bob.Bistrais at maine.gov>
wrote:
> Hi all,
> As I try to work through my security issues, I ran into another GeoMoose
> issue.  First, let me declare that I replaced the Dojo folder with the Dojo
> release 1.10.4.  Now, when I try to load the application, I see the
> following error in FireBug… TypeError:
> var layout = new GeoMOOSE.Layout.Default();
> -this appears to be in the main.js file.
> Any suggestions?
> Thanks again,
> Bob
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160121/d7d373c7/attachment.html>
More information about the Geomoose-users mailing list
