[Geomoose-users] Query
Brent Fraser bfraser at geoanalytic.com
Sat Jul 9 09:26:13 PDT 2016
Janet,
   Please direct questions to the Geomoose user's email list
(https://lists.osgeo.org/mailman/listinfo/geomoose-users) so everyone
can benefit (and you may get better answers).
In general, you need to:
1.  Confirm the coordinate system of your data in your PostGIS
database.  Is it EPSG:21037? EPSG:3857? something else?
2. Specify the coordinate system of your data in the MAP portion AND the
LAYER portion of your map file.
3. You may need to specify the data's coordinate system in the LAYER
data statement.  See Mapserver's documentation on PostGIS for more
details (http://mapserver.org/input/vector/postgis.html)
Best Regards,
Brent Fraser
On 7/8/2016 11:13 PM, Janet Maina wrote:
> Hi, am having parcels that should lie on these extents when i add
> google map layer
>  4114328,-127121 , 4148440,-112542
> the parcels displays well on this extent 249067 9852024 288545
> 9870842  and am able to display in geomoose but without google map
> layer. using
> PROJECTION
>     "init=epsg:21037"
>   END
> When I try to convert to ESPG: 3857 in Qgis 1.8 i get a blank map
> Please advice or give me the steps to convert. I think it is an issue
> of projection but I have tried with no luck
More information about the Geomoose-users mailing list
