[Geomoose-users] Vector editing with WFS-T
Jeff McKenna jmckenna at gatewaygeomatics.com
Sun Mar 13 14:51:43 PDT 2016
On 2016-03-13 5:07 PM, Brent Fraser wrote:
> Hey Jeff,
>    I've been successful with the Geomoose demo in using WFS-t to delete,
> modify and create "census_city" features, and to save these changes back
> to PostGIS (*Woohoo!*).  I'll have to edit our doc on the configuration
> (and file a couple of issues), but the main points are:
> 1. Add controls to the Census Cities layer in mapbook.xml:
> <layer title="Census Cities"  activate="true" src="census_cities"
> fade="false" unfade="false" metadata="false" legend="false"
> draw-point="false" draw-line="false" draw-polygon="true"
> edit-attributes="true" edit-shape="true" remove-feature="true"
> remove-all-features="true" buffer="true"></layer>
> 2. Add  "auto:true" to the save strategy in GeoMoose's WFS.js (line 36):
> this.save_strategy = new OpenLayers.Strategy.Save(*{auto:true}*);
>      - this means that when you unselect the feature after editing the
> changes will be automatically saved
> 3. Also in WFS.js, change line 44 to be:
> projection:*this.srsName*, // new
> OpenLayers.Projection(CONFIGURATION.projection),
> and in the mapbook add srs="EPSG:4269" to the mapsource:
>    <map-source name="census_cities" type="wfs" active="true"
> *srs="EPSG:4269"*>
>      - this causes OpenLayers to re-project the feature's geometry
> before passing it to TinyOWS (I don't think TinyOWS does re-projection).
> 4.  Set
> *check_schema="0*"
> in the TinyOWS config.xml file.  There are some schema problems I need
> to track down, but this works for now.
Regarding schema problems, I faced that too with the demo; to solve that
I had to copy the 'schema' folder from the tinyows source into
/ms4w/apps/tinyows/, so I bet that you would also have to copy that same
folder from /ms4w/apps/tinyows/schema/ to inside your GeoMOOSE
application directory, or, as you said, set check_schema to 0.
> 5.  When you create the table in PostGIS using ogr2ogr, make sure it
> creates it with geometry type of POLYGON by including "*-nlt POLYGON*",
> otherwise the type is MULTIPOLYGON and PostGIS complains when TinyOWS
> tries to insert a POLYGON.
> And thanks again for your TinyOWS demo; without that to confirm TinyOWS
> does actually work, I think I would have lost my enthusiasm ...
I'm glad it helped.  I remember spending like a week on that, figuring
out the schema problems and transaction errors.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
More information about the Geomoose-users mailing list
