[Geomoose-users] using WFS-T
Brent Fraser bfraser at geoanalytic.com
Tue Mar 15 07:38:21 PDT 2016
Hi All,
   Now that I've configured my Geomoose demo to do WFS-T, I need to
think about how to use it in my old Geomoose v2.4  Ice Digitizing
application.
   That application grouped digitized polygons by "image_id"
(representing the Landsat image used as a backdrop).  There are hundreds
of images and thousands of polygons in the system and when the user
selected an image, Geomoose passed the image_id to mapserver to do a
substitution in the mapfile SQL so only those polygons related to that
image were displayed (and available for edits etc).  That worked great.
How do I do the same thing with Geomoose v2.8 for my app?  Some possible
"solutions" (I like #3):
1.  Convert the old 2.4 vector editing system to a user extension and
use it instead of WFS-T
         - a lot of work, uses deprecated code, and no benefit to the
Geomoose community
or
2. Create a layer per image_id in the TingyOWS config.xml file and have
Geomoose switch layer name when the user selects the image.
     - as images get added to the system the config.xml file must be
updated (could be automated, but clunky)
     - each layer would point to a table in the database which would
make the database ugly
(hundreds of tables).  I might be able to use views instead of tables to
make it slightly less ugly, but TinyOWS might not do inserts into a
view.  Dunno about that.
     - could be some limitations on the number of layers in the
config.xml file (or performance issues?).
or
3.  Add functionality to Geomoose to accept attribute filters in the
mapbook and pass the filters to the OpenLayers definition.
     - adds complexity to the mapbook syntax (so more documentation,
testing, maint., etc).
     - the logic may be similar to the  mapbook's search/query mechanism
of specifying input types of layer,template,fieldname,comparitor,value
so maybe some of the code could be used.
or
4.  Other?
Thanks for any input!
Best Regards,
Brent Fraser
More information about the Geomoose-users mailing list
