[Geomoose-users] using WFS-T
Brent Fraser bfraser at geoanalytic.com
Mon Mar 21 10:23:28 PDT 2016
Jim,
   I've changed my mind.  I've implemented CQL filters to allow me to
easily do things like:
         <filter type="CQL">
             <![CDATA[reviewstatus_id<>24 and reviewstatus_id<>18 and
image_id = 0]]>
         </filter>
This requires only a minimal amount of code additions to Geomoose as
OpenLayers has a parser to convert CQL to its filter object.
And using the new API function would be like:
       var filter = "reviewstatus_id<>24 and reviewstatus_id<>18 and
image_id="+id;
       GeoMOOSE.updateLayerFilter("Icebergs_WFS",filter);
I'll file an issue, and after some more testing, I'll do a pull request.
Best Regards,
Brent Fraser
On 3/17/2016 9:45 AM, Brent Fraser wrote:
> Jim,
>   Yes, this is my thinking as well.  The additional mapbook syntax is
> a bit of a question mark, but I guess that would depend on how much of
> the OpenLayers filter syntax we would want to support.
>   For my purposes I've added to my wfs mapsource:
> <filter type="equal_to" property="image_id" value="204"/>
> but this will likely be too trivial for general cases since OpenLayers
> allows queries like:
>                 filter: new OpenLayers.Filter.Logical({
>                     type: OpenLayers.Filter.Logical.OR,
>                     filters: [
>                         new OpenLayers.Filter.Comparison({
>                             type: OpenLayers.Filter.Comparison.EQUAL_TO,
>                             property: "TYPE",
>                             value: "highway"
>                             property: "TYPE",
>                             value: "road"
> Not impossible but might take a little bit of design.
> Another possibility would be be to use CQL and let the user specify
> the CQL text then have OpenLayers parse it.  I've run across
> references to this in my Googling, but I don't know much about it.
> As for the Geomoose code, I'm hacking together some code to do:
> from my extension code:
>     params['image_id'] = id;
>     GeoMOOSE.updateLayerFilter("Icebergs_WFS",params);
> where geomoose.js has
>     updateLayerFilter : function(layerName, paramObject) {
> Application.getMapSource(layerName).updateFilter(paramObject);
> Now I have to do the rest of the coding...
> Best Regards,
> Brent Fraser
> On 3/17/2016 9:03 AM, James Klassen wrote:
>> I'm not sure this will work with the WFS layer, but this sounds like
>> something that GeoMOOSE.updateLayerParameters() would accomplish for WMS.
>> Currently (and subject to change between versions), you can get at
>> the underlying OpenLayers layer object with:
>> Application.getMapSource('mapbook/path')._ol_layer
>> This is something you could call from a script return from a service
>> or from a custom tab.
>> Having to dig in the internals in an unsupported way is what usually
>> prompts me to suggest additions to GeoMOOSE.* Generally, I just do
>> what I need to get done and after it shakes out for a bit figure out
>> how it could be done more generically.
>> Jim
>> On Tue, Mar 15, 2016 at 9:58 PM, Brent Fraser
>> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>>     Hey Eli,
>>       The filtering is for visual purposes: since images from
>>     different dates may be in the same location I want to see only
>>     those polygons related to the image being shown.
>>       My particular use-case is such that there will never be very
>>     many polygons served via WFS at once. but I do have some
>>     performance concerns in general.  Fortunately Geomoose/OpenLayers
>>     sends a bounding box filter based on the display window so that
>>     will tend to minimize the problem.
>>       I've hard-coded an OpenLayers attribute filter in WFS.js for
>>     testing purposes:
>>             this._ol_layer = new OpenLayers.Layer.Vector(this.title, {
>>                 strategies: strategies,
>>                 projection: this.srsName,
>>                 styleMap : this.style_map,
>>                 visibility: false,
>>     *            filter: new OpenLayers.Filter.Comparison({
>>     //BWF**
>>     **                type: OpenLayers.Filter.Comparison.EQUAL_TO,**
>>     **                property: "image_id",**
>>     **                value: "204"**
>>     **            proto*col: new OpenLayers.Protocol.WFS({
>>                     version: '1.1.0',
>>                     srsName: this.srsName,
>>                     url: this.url,
>>                     featureNS: this.featureNS,
>>                     featurePrefix: this.featurePrefix,
>>                     featureType: this.featureType,
>>                     geometryName: this.featureGeometryName,
>>                     schema: this.featureSchema
>>     and it works fine (the above code causes only those polygons
>>     digitized from image 204 to be shown).  Now I need to hack in
>>     some code to change the filter value when the user selects a
>>     different image.  While it will be ok for my project, it would be
>>     nice to come up with a more general approach.  Maybe I'll get
>>     some inspiration while hacking...
>>     Best Regards,
>>     Brent Fraser
>>     On 3/15/2016 5:57 PM, Eli Adam wrote:
>>>     Hi Brent,
>>>     On Tue, Mar 15, 2016 at 7:38 AM, Brent Fraser<bfraser at geoanalytic.com> <mailto:bfraser at geoanalytic.com>  wrote:
>>>>     Hi All,
>>>>        Now that I've configured my Geomoose demo to do WFS-T, I need to think
>>>>     about how to use it in my old Geomoose v2.4  Ice Digitizing application.
>>>     Cool, good to hear that it is working.
>>>>        That application grouped digitized polygons by "image_id" (representing
>>>>     the Landsat image used as a backdrop).  There are hundreds of images and
>>>>     thousands of polygons in the system and when the user selected an image,
>>>>     Geomoose passed the image_id to mapserver to do a substitution in the
>>>>     mapfile SQL so only those polygons related to that image were displayed (and
>>>>     available for edits etc).  That worked great.
>>>     Is filtering for visual purposes so that you can see what is going on?
>>>       Or is filtering for performance and browser limits?  Did you try
>>>     solution 0 which is to do no filtering and see if it works?
>>>>     How do I do the same thing with Geomoose v2.8 for my app?  Some possible
>>>>     "solutions" (I like #3):
>>>>     1.  Convert the old 2.4 vector editing system to a user extension and use it
>>>>     instead of WFS-T
>>>>              - a lot of work, uses deprecated code, and no benefit to the
>>>>     Geomoose community
>>>>     or
>>>>     2. Create a layer per image_id in the TingyOWS config.xml file and have
>>>>     Geomoose switch layer name when the user selects the image.
>>>>          - as images get added to the system the config.xml file must be updated
>>>>     (could be automated, but clunky)
>>>>          - each layer would point to a table in the database which would make the
>>>>     database ugly
>>>>     (hundreds of tables).  I might be able to use views instead of tables to
>>>>     make it slightly less ugly, but TinyOWS might not do inserts into a view.
>>>>     Dunno about that.
>>>>          - could be some limitations on the number of layers in the config.xml
>>>>     file (or performance issues?).
>>>>     or
>>>>     3.  Add functionality to Geomoose to accept attribute filters in the mapbook
>>>>     and pass the filters to the OpenLayers definition.
>>>>          - adds complexity to the mapbook syntax (so more documentation, testing,
>>>>     maint., etc).
>>>>          - the logic may be similar to the  mapbook's search/query mechanism of
>>>>     specifying input types of layer,template,fieldname,comparitor,value so maybe
>>>>     some of the code could be used.
>>>     This sounds like an option worth exploring and may have other general
>>>     applicaitons.
>>>>     or
>>>>     4.  Other?
>>>     My ideas are sort of light on this one, hopefully others have further ideas.
>>>     Best regards, Eli
>>>>     Thanks for any input!
>>>>     Best Regards,
>>>>     Brent Fraser
>>>>     _______________________________________________
>>>>     Geomoose-users mailing list
>>>>     Geomoose-users at lists.osgeo.org
>>>>     <mailto:Geomoose-users at lists.osgeo.org>
>>>>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160321/42b2cb15/attachment-0001.html>
More information about the Geomoose-users mailing list
