[Geomoose-users] startup service
Brent Fraser bfraser at geoanalytic.com
Sun May 15 16:07:49 PDT 2016
Dan,
   Now that the startup_service specified in the mapbook or config.js
works (or at least it should; I'm still having problems getting any of
the three startup methods to work using yesterday's nightly build), I
expect my original problem would still exist: the toolbar will be disabled.
I did notice this in the GeoMOOSE doc
(http://docs.geomoose.org/2.8/docs/configuration.html#configuration):
services.disable_others
   Toggle whether tools and other tabs should be disabled when starting
a service.
I wonder if this would solve my problem of having a startup service with
no user input needed?
Best Regards,
Brent Fraser
On 3/29/2016 2:10 PM, Dan Little wrote:
> The disabling of the toolbar is actually a new usability 'feature.'
>  One of the big struggles that both Jim and Eli found in the UI was
> the order of operations when multiple services were starting at the
> same time due to the 'open' nature of the toolbar operation.  You can
> see this in operation in the current demo when you click the "Search
> Parcels" tab.  The only way to get the toolbar back is to click
> "cancel" which allows the service to clean itself up properly.
> If you've got a specific tab that you want displayed all the time it
> may be necessary to write it as a custom-tab extension.  Which in 2.9
> is going to get a bit easier.
> On Tue, Mar 22, 2016 at 3:49 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
>     Hi devs,
>       In my task to upgrade my digitizing app, I see a couple of things:
>     1.  That specifying a startup service in the URL  disables the
>     tools in the toolbar
>     2.  Specifying a startup service in the mapbook or in config.js
>     doesn't seem to work.  And I can't find any place in the code
>     where startup_service is referenced.
>     So I added a few lines to main.js (at line 73):
>             var params = GeoMOOSE.getUrlParameters();
>             if(GeoMOOSE.isDefined(params.call)) {
>                 var service_name = params.call;
>                 delete params.call;
>                 GeoMOOSE.startService(service_name, params, true);
>     *        /*  --- new: --- */**
>     **if(GeoMOOSE.isDefined(CONFIGURATION['startup_service'])) { **
>     **            var service_name = CONFIGURATION['startup_service'];**
>     **GeoMOOSE.startService(service_name, params, true);**
>     while it does start the service in the config.js, but it has the
>     same effect on the toolbar as specifying "?call=myservice" in the
>     URL (it is disabled).
>       Is there something special I need to set to enable the toolbar
>     after a startup service?
>     Best Regards,
>     Brent Fraser
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160515/622738a4/attachment.html>
More information about the Geomoose-users mailing list
